Calculators in the workshop
Home Forums Model Engineer & Workshop Calculators in the workshop
  • #38136
    Deric
      @deric
      Using calculator to count up and down?
      Deric
        @deric
        Hi, all,
        Can anyone else remember an article either in ME or MEW about modifying a cheap calculator to count up and down the revolutions of a handwheel by connecting it to a reed switch?
        I've been through all the back copies and I can't find it but I know I've read it somewhere!
        Anybody help?
        Best regards
        Deric
        #93487
        dcosta
          @dcosta
          Hello Deric,
          Using MEW_Indexes **LINK** i found the following:
          Subject: Lathe
          Title: Cheap and simple turns counter
          Author: Fletcher
          Issue: 114
          Page: 46
          Year: 2006
          Montyh: April
          Subject: Quick tip
          Title: Counting handwheel turns
          Author: Rhodes
          Issue 83
          Page: 22
          Year: 2000
          Montyh: July
          Hope this helps.
          Best regards
          Dias Costa
          #93488
          Ian S C
            @iansc
            I'v got one some where that I used as a counter for coil winding, just a couple of wires, one attached to the winder, the other so it touches once per rev.Can't remember how I wired it up, and I think you have to push 1 then +. Ian S C
            #93490
            John Shepherd
              @johnshepherd38883
              Deric
              To use a calculator to count you can connect a reed swich across the '=' button. Press +1 and then each time the reed switch operates the calculator will count up by one. If you then enter -1 it will count down.
              Deric
                @deric
                Thank you all for your replies.
                I knew I could rely on you for an answer. I'm off to the £ shop now for a cheap calculator.
                Thanks again
                Deric
