Calculating volume in metric
Home Forums Beginners questions Calculating volume in metric
Viewing 25 posts - 1 through 25 (of 48 total)
  • #139414
    JC Uknz 1
      @jcuknz1
      Been using metric for years but always fould up when calculating a volume.
      Currently have a boiler 50mm diam and 150mm long
      25x25x3.142 x150 gives me 2904562.5
      Now the bit that trips me …. converting the cubic mm to litres
      Is it 1000x1000x1000? That gives me 0.0029045 which seems awefully small. Judging from my one litre milk bottle it could be about a quarter to a third litre
      Boiler for Mamod modification accourding to Aussie boiler regs must not be bigger than one litre.
      Side note …
      I know Manods go well as they are but this is a Mamod Garrett
      Your help much appreciared.
      JC Uknz 1
        @jcuknz1
        #139415
        David Jupp
          @davidjupp51506
          1 ltr = 1000 cc = 10cm x10cm x10cm = 100mm x 100mm x100mm.
          Answer should be 0.29 ltr or so.
          #139416
          clivel
            @clivel
            Hi JC,
            25x25x3.142 x 150 is 294562.5 mm3 not 2904562.5 somehow an extra zero crept in there.
            1 litre=1000000 mm3
            so your boiler should be 0.2945625 litres
            #139417
            Steamgeek
              @steamgeek
              I make the calculation 0.294 litres, you appear to have an extra 0 in your calculation ( after the 9 )
              The conversion from cubic mm to litres is 10E-6 ( move the decimal point six places to the left )
              #139418
                If you work on the fact that 1 litre takes up a space 100mm x100mmx100mm you can work it out a s
                0.25 x 0.25x 3.142 x 1.5 =0.295lts
                or do it as you have in mm then divide by 1,000,000 (100x100x100)
                #139419
                Gary Wooding
                  @garywooding25363
                  Posted by JC Uknz 1 on 02/01/2014 07:44:32:
                  Not quite. You're 1000 times too small – (and you inserted a zero between the 9 and the 4).
                  1 ltr = 1000cc
                  1cc = 1000 cubic mm, so 1ltr = 1000 x 1000 cubic mm.
                  So your boiler = 0.2945625ltrs.
                  For volume measurement its much easier to work in cm rather than mm. In which case your calculation would be 2.5×2.5×3.142 x15 = 294.5625cc = 0.2945625ltrs.
                  #139421
                  John Haine
                    @johnhaine32865
                    Er, that would be 1E-6…
                    #139423
                    Ady1
                      @ady1
                      1000cc = 1 litre, like a car
                      So keep things as cubic cm
                      2.5 *2.5 *3.14= 19.63 cubic cm
                      *15cm = 294.52 cubic cm, about 0.3 of a litre
                      simples!
                      #139424
                      MICHAEL WILLIAMS
                        @michaelwilliams41215
                        When doing any engineering calculation it is always useful to have a general idea of the magnitude of the answer . You can get this from other similar calculations done before , from practical experience , from much cruder preliminary calculations or from a rough practical test .
                        In case of this boiler :
                        If it already exists just fill it with water and run water off into measuring jug . Indeed that would probably give a sufficiently good answer .
                        If boiler exists only on paper the use any of :
                        Visual comparison of drawn boiler ( or cardboard mockup) with any existing container of known capacity something like same size and shape – kitchen jug , milk carton or beer glass . Visual comparison could easily be accurate to within 10 % and again that may give a sufficient answer directly .
                        Regards ,
                        MikeW
                        #139428
                        speelwerk
                          @speelwerk
                          1 litre=1 cubic dm, so if you start the caculation with all the dimensions in dm (decimetre) then your answer is in cubic dm which is equal to litres, 25mm=2.5cm=0.25dm. Niko.
                          Edited By speelwerk on 02/01/2014 10:29:53
                          #139430
                            JC U,
                            It'sprobably obvious by now; but I think it worth noting that your original division by (1000x1000x1000) gives the volume in cubic metres … and one cubic metre is roughly the size of those one tonne bags of sand that they crane off the delivery waggon.
                            Incidentally, for the purposes of boiler volume, I wouldn't worry about expressing litres to the seventh decimal place. [just think what a tiny volume that last place represents]. !!
                            As MikeW suggests [and you already knew from your Milk bottle] … Domestic containers are very useful for the "sanity check".
                            S.D.L.
                              @s-d-l
                              The easy way is to remember 1000 litres = 1 cubic meter = 1 tonne of water =1000kg
                              This makes sizing tanks very easy
                              So if working by dimensions work in meters and multiple by a 1000
                              eg 0.025 x 0.025 x 3.142 * 0.150 = 0.000294562m^3
                              multiply by 1000 gives 0.294 liters
                              this saves worrying about no SI units or units that you don't use much.
                              The easy way is to weigh boiler empty fill then weigh again difference is weight of water 1 litre = 1kg = 1000 grms so if the difference was 294g would be 0.294lts
                              Steve
                              #139440
                              Russ B
                                @russb
                                And the winner of the quickest combined mistake spotting and volume calculations goes to …..
                                #139456
                                jason udall
                                  @jasonudall57142
                                  50 mm * 150 mm…..about a drinks can…300 ml 0.3 l
                                  Btw 200 l ” forty gallon drum”..seems much more than a cubic meter let alone a fifth. .
                                  #139457
                                  jason udall
                                    @jasonudall57142
                                    Just checked ( my own disbelief)
                                    44 gal imp
                                    55 gal us
                                    210 l
                                    24 ” dia 36″ high…
                                    Funny seem much bigger..but there goes
                                    #139469
                                    Sub Mandrel
                                      @submandrel
                                      It cheers my Imperial sensitivities to see so many 'up to date' metric head advocating the long-deprecated cubic centimetre!
                                      JC Uknz 1
                                        @jcuknz1
                                        Thankyou all for rushing to solve my problem .. the thing to remember apart from the obvious decanting and filling up a known container … would work except I have only got as far as cutting the tube and one end …. .. thanks again
                                        Jason that doesn't relate to me as I drink from glass stubbies
                                        The extra zero comes from my fingers inaccuracy and my brain not checking what they had done
                                        I will remember what Steam Geek wrote "The conversion from cubic mm to litres is 10E-6 ( move the decimal point six places to the left )" … the first bit is above me but the bracketted makes sense
                                        #139472
                                        JC Uknz 1
                                          @jcuknz1
                                          Just realised I could seal one end of he tube with gladwrap and do the decanting in to my 300ml jug.
                                          I remember my first use of metrics was at school during WWII in Mech Drwg when I 'thought' the millimeter markings a much easier way of measuring drawings than the imperial on the other side … I guess it relates to I still have ten fingers and ten toes despite my activities of the following years.
                                          I wonder if it was a metrician's plot that the imperial side of theschool ruler was beveled and flopped around whereas the metric side sat flat on the paper
                                          #139476
                                          Falco
                                            @falco
                                            The following was given to me as an explanation of how the metric system ties together in the practical world.
                                            It may help anyone not using to it to visualise the connection between length , volume and weight in the metric system.
                                            The weight measurement is correct only if the contents are water.
                                            A little cube box with sides 1 x1 x1cm. will hold 1ml. of water. The water contents, (excluding the weight of the actual box), will weigh 1 gram. (Think sugar lump)
                                            A cube with sides of 10x10x10cm. will hold 1000 ml. (1 litre), and will weigh 1000 grams or 1 kilogram.(kg). (Think milk carton)
                                            A cube with sides of 100x100x100cm, (ie. 1x1x1metre) will hold 1,000,000ml, or 1000 litres and the water contained will weigh 1,000,000 grams, or 1000kg or 1 tonne, (Think of the builders sand bags mentioned by MichaelG )
                                            stevetee
                                              @stevetee
                                              This is my problem with the metric system, the calculation is easy as all ( well most then) of the units are related to one another . No poundals or degrees f or calories to struggle with. Making sense of the answer is where the problems begin.
                                              I think that any system that uses the same unit to measure the height of a kitchen work top (900mm) as is used to measure the thickness of a piece of paper (0.01mm) is bound to suffer from problems of where does the decimal point lie, how many zero's?. In the case of this boiler it's not 2.9 litres ( half a gallon) or 0.029 litres ( half a teaspoon) so it must be .29 litres., but you do have to jump the decimal point 5, 6 or 7 places to get an answer that makes sense.
                                              I actually rang up the BBC one morning because there was a government minister and a presenter on the news discussing keeping a jerry can of petrol holding 201 litres in your garage( remember the tanker drivers strike). Some idiot had written 20 litres down as 20l , read out on the radio as 201 litres and neither of them realised they were talking about a volume of around 40 gallons, try picking that up.
                                              We used to have a system with measurements like 'An inch and seventeen thirtytwos, plus or minus five thou'. I mean where could that go wrong
                                              Edited By stevetee on 03/01/2014 00:01:43
                                              #139499
                                              speelwerk
                                                @speelwerk
                                                The person writing 20litres as 20l is doing it correct, the same goes for grams, it is 20g not 20grms. Niko.
                                                Edited By speelwerk on 03/01/2014 00:24:33
                                                #139500
                                                Mark C
                                                  @markc
                                                  I think you might find that the correct way should have a space between the numbers and the letter.
                                                  Mark
                                                  #139503
                                                  speelwerk
                                                    @speelwerk
                                                    Posted by Mark C on 03/01/2014 00:35:28:
                                                    Mark
                                                    I will keep it in mind. Niko.
                                                    #139509
                                                    MICHAEL WILLIAMS
                                                      The correct and most useful way to write down metric quantities is to use the descriptor lettering as the decimal point and prefix this with the decade count lettering .
                                                      For instance : 4756 grammes is 4Kg756
                                                      Works well with dimensions :
                                                      34.5 Metres is 34M5
                                                      0.463 Metres is :
                                                      0M463
                                                      46CM3
                                                      463MM0
                                                      Note intrinsic use of significant figures . Used properly it avoids the common use of long meaningless decimal values .
                                                      MikeW
