Calculating Feedrates for drilling with the Sieg KX1
Home Forums CNC machines, Home builds, Conversions, ELS, automation, software, etc tools Calculating Feedrates for drilling with the Sieg KX1
  • #486459
    Steve Withnell
      @stevewithnell34426
      I've been puzzling over the feed rates when drilling with a CNC. I found this table, but it doesn't link to material type. How do I calculate feed rates when drilling?
      A specific would be drilling 3mm holes in EN3 square bar as opposed to drilling 3mm holes in aluminium. How do I go about calculating the feedrate in those different materials.  If I use that data, then I get to 150mm/minute in mild steel – is that about right?
      Table:
      Recommended Feeds of Various Diameter Drills
      Diameter of Drill – Inches Feed Inches per Revolution
      Under 1/8 001 to .003
      1/8 to 1/4 .002 to .006
      1/4 to 1/2 .004 to .010
      1/2 to 1 inch .007 to .015
      Edited By Steve Withnell on 18/07/2020 17:07:42
      Steve Withnell
        @stevewithnell34426
        #486463
          Fusion chucks out speed of 2910rpm and plunge rate of 131mm for 3mm drill in low carbon steel
          #486478
          Steve Withnell
            @stevewithnell34426
            Thanks Jason, I calculated manually 3032 rpm and 156 mm/minute which is a bit more aggressive, but I can see that I've been a bit optimistic with the "feed inches per revolution" value. If I back it off to where it should be I get your numbers. I'll go and run with that, see how it works out!
            Steve
