Anna,
Long post so go get a coffee.
I used to have an ML7, bought new from Myfords and it served me well for many years.
I always wanted a screwcutting gearbox but they were too expensive for me at the time. Years later I came across one quite reasonable so bought it and fitted it to my lathe.
I wanted one to save the hassle of keep changing gears for the wide variety of jobs I was doing
I then had to buy the new banjo and conversion gears from Myfords for doing metric threads, as there were no cheap rubber Indian copies I had to pay full price.
After doing a few imperial threads then metric threads I realised I had made a big mistake in doing this conversion. Let me explain.
When in imperial mode provided that the ration needed is in the box then there is no problem. You have quickly selectable ratios and a quickly selectable fine feed arrangement by just turning the gear over which requires no tools, after all this is what it was designed for in 1953 when metric was well into the future.
The problem comes about when you swap to metric screwcutting. Instead of having to replace a few change wheels on a banjo yo now had to strip the original banjo, replace it with a new one and then populate this with the gears needed. Far, far more work than swapping gears on a non- gearbox lathe.
Added to this you lost the fine feed arrangement when in metric mode and if needed entailed the whole job lot to be swapped over again.
It was this constant swapping that made me realise that I had made a bad decision in fitting the gearbox. Shortly after this I sold the lathe as room was needed for a far larger lathe.
In hindsight and knowing what I now know IF I still had the lathe I would keep the gearbox and the default original drive and purchase just two additional gears to enable the standard box to cut metric AND still have the default fine feed arrangement.
The gearbox machines have a 24 tooth input gear on the tumbler shaft as standard.
If this gear is replaced with a 33 tooth or 34 tooth, depending, then the standard box will cut all the common metric threads from 0.45 to 4.5mm pitch and BA sizes from 0 to 8 although a 20 and 21 is also needed for some of these sizes.
It is far easier to replace one gear than swap a load or the whole banjo.
Now if David will allow me a small plug these gears with a laminated chart can be bought here
John S.
Edited By John Stevenson on 04/09/2011 20:40:48
