cagoule tapes
cagoule tapes
Home Forums The Tea Room cagoule tapes
  • #641897
    duncan webster 1
      @duncanwebster1
      Nothing to do with engineering, but you lot are a fount of all knowledge. The tapes across the seams on my cagoule have started to fall off. Anyone know what type of glue is used to stick them on?
      duncan webster 1
        @duncanwebster1
        #641899
        Jelly
          @jelly
          Mcnett Aquasure or Aquaseal UB will do a decent job but will remove any breathable properties where it is applied so be precise if it's goretex or equivalent, spread it very thinly or it will noticably stiffen the seam.
          Seamgrip is an alternative if you'd prioritise flexibility over durability.
          If it's goretex or the like Shelby.fi will mail order you heat-seal breathable tape to apply with an iron (there's a lot more to it, so do some reading if you go that route)
          In the unlikely event it's an ultra lightweight silicone coated nylon cagoule you'd need Silnet.
          #641924
          duncan webster 1
            @duncanwebster1
            Thanks, seam grip ordered.
