From John Stevenson:
Cad is like religion, one copy will not suit everyone. It’s no good taking someone’s recommendation that theirs is the best program. You can see this in the replies above where many different programs have been touted.
CAD is a learning curve, how steep depends on the user but the first part is to download at least 4 or 5 demo’s and spend at least a full night with each to see how the way it draws suits you .
If you are not prepared to put this level of work into finding one you will never get the best out of a program. It sound s a lot of work but once you are proficient with a program it pays back in spades as regards accuracy and production.
I would totally agree with the above comments. Although I use Design Cad, and have done for a good few years now, and am reasonably conversant with the major features, even now I will struggle if trying to do something new.
What this also means is that I am not prepared to swap to another program. Having been through one learning curve, I don’t need another. Having said that, the reason why I did not get on with TurboCad was because I was already spoiled by Draft Choice, which despite it being a shareware program, was in my opinion better written and better featured than the TurboCad program of the same age. Nevertheless, given the advances in all CAD programs, I imagine that anyone coming to TurboCad with no preconceived notions may well find it OK. At least it is easy to find.
About Draft Choice for Windows. This was the program I first learned on and which I found very good and easy to use. It also had an excellent (no other word for it) tutorial. In particular, as a confirmed disliker of the mouse, this program enabled me to apply most, if not all, commands from the keyboard, (I find that keyboard action is generally so much faster than faffing around with the mouse.) and when it eventually failed to work following computer & operating system upgrade, I had to find a replacement. This is where Design Cad came in. I was fortunate enough to find a cheap enough copy to risk scrapping it (£13 inc p&p) and was initially very much intimidated by all the available functions, but I did find that there were a lot of similarities to Draft Choice, sufficient for me to make the transfer reasonably easily.
I did not find Allycad, but if I had, I may well have been put off by the cost, although I do note that there is a file size limited, but otherwise fully functional free download. In respect of the size limitation, most of my files are less than 100kb, but I do have a small number approaching the 300kb limit, and one of over 1Mb – and none of my drawings are by any means complex. I suspect this 300kb limit may well become a serious limitation.
Peter G. Shaw
Edit.
Also agree with Circlip. Don’t pay lot’s of money. Even my favourite can be obtained for £25. Have a look on ebay. Read any forums you can find about whichever program you are interested in. What you may find is that one particular earlier version is rated on the forums as being better made than later versions – and will be much, much cheaper. Also don’t buy the latest version – it may well have unknown bugs in it.
Edited By Peter G. Shaw on 21/03/2010 12:41:09
