Chromebooks are a highly cost-effective way of getting reasonable hardware in a small package with a long battery life between charges. And there's no buried Micros**t licence fee to pay… However, the limited on-board storage may initially be seen as a limitation. Therefore, it's probably a good idea not to clog up the ssd with multiple operating systems. ChromeOS is designed for an on-line existence and is too limiting (and annoying) for general use (and would you trust Google anyway?), so why bother with a dual-boot set-up?
The solution is to get rid of all the originally-supplied firmware and ChromeOS and run Linux alone. This is being written on such a device. It works perfectly. I have played with various Linux CAD packages on this machine: all worked fine, as far as I could see.
This site has been devoted to running Linux on Chromebooks for several years and contains all you need for the conversion. I admit to not understanding all of the techy stuff, but following the instructions was easy and successful. I'm running GalliumOS, a light-weight Linux distro optimized for Chromebooks, on an Asus C200, now several years old. It's easier to replace the firmware on later machines. The whole process is reversible, should you wish to sell the machine as an unmolested Chromebook (but why would you?).
You can also do a similar trick to run Windoze on a Chromebook, but really…?
Edited By Kiwi Bloke on 11/01/2020 21:25:05
