An Update on the TurboCad for Mac free trial.
As expected, some things I found better or simplier than AutoCad and others not so. For example, all lines are done by just inserting a length and an angle which was quick and easy, but I had trouble with drawing just a single line, the system often wanted me to add another line, me being unable to remember how to terminate the command correctly I suppose. There is no ‘erase’ command as in AC, you just highlight what wants erasing and hit the keyboard ‘delete’ key (like other Mac programmes) – spent ages looking for the ‘erase’ command!
The copy command wasn’t as clear as in AC, being tied in with the ‘move’ command.
Snaps could be a pain sometimes unless you zoomed in on that bit you were working on – but I guess to a lessor degree that happens in AC as well. Dimensioning was good, but some problems arose when the dimension gave a figure different to that drawn. For example, a line of 30.00mm long became 29.998mm on the dimension – weird. To get over this one I eventually had to draw a 30.00mm line away from where I wanted it ( a redraw in the position didn’t work) then move it into position. But multiple dimensioning, and multiple verification of lengths, is easier than in AC.
The grid does not do just dots, you have to have lines, and dots as subdivisions. If I use a grid I prefer just dots and as the lines I found were intrusive I reverted to pencil and paper practice and worked with a blank white sheet.
Good feature was that I could import a load of AC drawings into TC. At first as imported it seemed as if nothing was there, but, after import I found that if the layers were set up in the TC drawing as on the AC drawing then bingo, all was revealed. But the layer command does not include for different line styles which I prefer, all lines are as set in the drawing default. If a line needs to be different then you have to select it and change it with the required style.
Printing was good too, for me. I only printed on A4 (because that’s all my printer does) but you can overlay the drawing on a representation of the paper for a preview and select a scale to suit – you can also select odd-ball scales, like 0.65:1 instead of 0.5:1, or 1/2 scale, if you really wanted. You have to watch the sizing of drawing and dimension text as it varies with the scale selected for printing -what looks good on the screen may appear huge or tiny when printed, depending on printed scale!
All in all I found the TC for Mac to be good and to do all that I wanted to do, and all that I guess the majority of model engineers will require too – and that was without trying the 3D facility (I ran out of time to play with that) – but only the individual can be the judge of that. It really could do with a more detailed instruction manual although the online help guide and the basic tutorials were very useful. A lot of what is available on AC Lite is available on TC – it’s just finding it and how to use it that is sometimes the problem!
Version 6 is due out anytime now – should have been out 6 weeks ago – and prices seem to be coming down for the package, so rather than buy Ver.5 and then upgrade to Ver.6 I am waiting for Ver.6, although I don’t know what ‘extra’s’ Ver.6 will bring.
I hope the above will help any Mac users thinking of TC – best thing is to download the free trial and play with it, see if it is for you.
ChrisH
