There are two common issues:
1/ Bleeding, which Stuart had, where the segmets get dark and blurry. seems to be caused by contamination of he liquid in the display.
2/ Weak or ghosting segments often cused by bad zebra strip directionally conductive rubber. This can be cured by removing , cleaning and resaeting the display, PCB and stip. Use a lint free cloth dampened with IPA to gently wipe the glass edge of the display, PCB and both edges of the strip. Don't wet the display or strip with solvent and don't touch the contact areas with bare fingers. Reassemble with care.
Flukes are great (I have 7
, the 8010A make a nice bench meter and the physically similar 8050A is more accurate with 4.5 digits instead of 3.5. There are a lot of Ex MOD Fluke 25's on the mrket at the moment. These are a rugged, waterproof autoranging meter that works well and is more accurate than their new basic models.
Robert G8RPI.
