BV25 Lathe?
BV25 Lathe?
Home Forums Model Engineer & Workshop BV25 Lathe?
Viewing 14 posts - 26 through 39 (of 39 total)
  • #106079
    Ex contributor
      @mgnbuk
      Axminster BV20 on Ebay at the moment. Item 290827970256
      John Clipstone
        @johnclipstone31156
        Perhaps a little late but for those interested in more information on the model BV25 lathe. A very careful look at figure 4 in the article will reveal the logo for Adendorff Machinery Mart a Johannesburg based company similar to Machine Mart. Their machinery brand name is Mac-Afric (similar to Clarke for Machine Mart) Web address http://www.tooltime.co.za. (Worth a look for a change).The BV25 is shown on page **LINK** where you can download a sales leaflet and the operatring manual :
        **LINK** for the sales leaflet
        **LINK** for the 30 page operating manual and parts diagams.
        John C.
        #111344
        oldvelo
          @oldvelo
          Hi
          I found this topic In MEW Forum. If you Google "bv25b-l lathe" it brings up lots of dealers selling this lathe.
          This was the lathe I bought for my home workshop and did some modifications-improvements to get a better performance.
          The Topslide angle that several mention is totaly down to personal preference myown being as follows.
          The angled topslide set at 29.5 degrees is what is used for thread cutting 60 degree threads
          1) Set the tool to touch the workpiece and set Crossslide Dial to zero.
          2) Move apron to allow the tool to advance on the Crossslide and advance the tool to the depth of thread required.
          3) Zero the Crosslide Dial again.
          4) Zero the Topslide Dial then retract the tool with the TopslideHandle until it will clear the Workpiece by moving the Apron.
          5) Advance the tool with the Topslide and take the first cut
          6) STOP The Chuck and retract the tool with the Crosslide and REVERSE the Apron with the Leadscrew Engaged.
          7) Stop and Advance the Crosslide back to Zero.
          8) Advance the tool on the Topslide.
          9) Keep repeating 6) 7) & 8) until the Topslide dial reads Zero
          If you got it right the Thread just needs tidying up.
          Not being nimble enough with my advancing years I have fitted a 180 volt DC motor that extends the Variable Speed range from 40 to 2500 RPM
          The original was 115 to 1620 in six steps
          Eric
          #111638
          oldvelo
            @oldvelo
            Hi more on bv25 lathe also marketed as Weiss ML260
            http://www.machines4u.com.au/view/advert/ML260/28291/
            Specs are the same as bv25b-l with a few additions and modifications.
            Eric
            #115927
            Jan-Erik Hammerstad
              @jan-erikhammerstad96838
              Hi.
              I have a BV25B-L.
              I miss a change gear for the thread setup. Its the 75 teeth . Where can I buy one???
              I have modified the lathe slightly. New belt wheel on the motor with the original ratio and one track with half the diameter because the 115 rpm speed when turning threads was a bit high for me. I changed the belts from the chinese ones to some from Mitsubishi. There was a rumble when in lower gears with the chinese belt, but with the Mitsubishi there is no rumble and it sounds tight andgod.. Must have been the bad construction in the chinese belts that made this chatter.
              The compound where not nice to use as it felt variable hard . I have installed 2 thrust bearings and its as night and day. Easy to use.
              i have also put a quick change tool post.-
              Am very satisfied with the lathe
              #116021
              oldvelo
                @oldvelo
                Hi Hammerstad
                Cutting threads will be a lot less stressful with the spnidle running at 57.5 rpm.
                I had the same problem until I converted the drive to "Polly Vee Belts" with three speeds of
                115, 87.25 and 57.5 gave muc more control.
                The chatter from the gearbox can come from a single phase motor check the reply from
                "Ken" he describes how it occurs in great detail
                http://www.homemodelenginemachinist.com/f16/single-phase-motor-chatter-17383/
                Someone on this forum may be able to help in cutting a gear for you now you have made the call
                One Little thing with a BV25B-L lathe change gear is that the diameter in mm = the number of teeth
                therefore no need to count teeth just measure the diameter.
                Be aware that the ball bearings on the input shaft are liable to fail and kick up a racket
                Check that the oil hole to feed the bearings has be drilled correctly as the hole was completly ommited from mine causing failure shortly after I Bought it.
                Oil changed and new bearing on the intake shaft and the problem solved.
                Eric
                #116248
                Jan-Erik Hammerstad
                  I have a BV25B-L about 6 years old , but used only some hours due to bad health.
                  I do not have the users manual for it. Are there anybody that have this electronically? I would very much appreciate to get it (buy).
                  Jan-Erik
                  #116262
                    Posted by Jan-Erik Hammerstad on 06/04/2013 21:58:18:
                    Jan-Erik
                    Jan-Erik
                    John Clipstone's post [above] has a direct link to a free PDF manual of 30 pages.
                    Jan-Erik Hammerstad
                      Thanks for the answer, but the lathe shown in the links is not the BV25B lathe, some similarities but anther concept.
                      It has been very difficult to get this users manual and also other info on the lathe.
                      Jan-Erik
                      #116313
                        Jan-Erik
                        Sorry for my error
                        Andyf
                          @andyf
                          I see that the BV25 lathe first appeared in MEW issue 198, with a second article in 199, but despite a "to be continued" we have heard no more about it in the last two issues. Maybe it has been dropped because of the mystery it seems to have created. If so, that seems a pity to me. There are many articles in MEW about machines I have never seen and am unlikely ever to own, but are interesting to read and often contain ideas which can be adapted to my own purposes.
                          Andy
                          #116334
                          David Clark 13
                            @davidclark13
                            Hi There
                            It is back in 202.
                            We have plenty more articles in the series.
                            regards David
                            #116357
                            Andyf
                              @andyf
                              Posted by David Clark 1 on 08/04/2013 08:59:21:
                              ….. It is back in 202….
                              So it is. 202 dropped through my letterbox an hour ago.
                              Andy
                              #116394
                              Sub Mandrel
                                @submandrel
                                Posted by Andyf on 08/04/2013 13:18:15:
                                Exactly! personally posted by David Clark 1. Now when will he get here with mine?
                                Hah! After careful cross-examination of the Senior Partner I discover she's helpfully put it on the landing windowsill…
