Here are a couple more simulations, using a transformer rather than a coil. The output graph in each case represents the output of the secondary. The inductance of the primary is 100µH as before, for the secondary 10mH, on the naive basis that the turns ratio is 100:1, and the mutual inductance is 600µH, implying a coupling coefficient of 0.6. Here's the picture for the basic transformer:
and for the capacitor with transformer:
No great surprises, bigger voltages all round! I'm not sure why the oscillation in the case with the capacitor/transformer appears to be truncated for a short period after the first oscillation. I suspect a limitation of the simulation. In the real world both the diode and transistor would have let out the magic smoke long before. It seems pointless trying to simulate a spark gap, so I'm not going to try. Instead onto the real world and I'll try some tests with my experimental ignition coil. I might get time this weekend as it looks like the weather is going to degenerate into showers, so no flying,
, but that does mean more time for playing at engineering
