I also have a 6×4 bandsaw, bought the SIP version from G&M tools about 15 years ago for about £100.00, hardly used it for many years as it would not cut straight – blade used to come off the top bearing and refuse to go back on.
Recently changed the blade and adjusted the bearings properly and it cuts much better now, I can't believe the price increase in this item now at 3x the price of what I paid!
I also picked up an Evoultion Rage 2 – 355mm cold chop saw on 'the bay' for £40.00 a few years back, this cuts through just about anything in seconds and does not leave nasty hot burrs. I have used it to trim 1-2mm from the end of a 20x40mm aluminium extrusion that was slightly too long as supplied – perfectly smooth square cut with no heat.
Edited By Timothy Moores on 13/05/2016 08:11:15
Edited By Timothy Moores on 13/05/2016 08:13:10
Edited By Timothy Moores on 13/05/2016 08:13:22
