Butterfly Bolt or Thumb Screw
Home Forums Beginners questions Butterfly Bolt or Thumb Screw
Viewing 23 posts - 1 through 23 (of 23 total)
  • #484108
    Chris TickTock
      @christicktock
      Hi,
      I am in the process of converting my scroll saw and the blade holders currently are M4 cap headed socket screws marked 8.8 which is I think high tensile alloy steel.
      It would be an advantage to replace the cap headed screws with finger tightening screws such as thumb or butterfly.
      My issue is that yes I can find stainless screws to my requirements but not strong steel. Easy to find cap headed screws so is there a way to convert a normal cap headed to convert to thumb or even better butterfly.
      I have found one site offering really strong durable M4 butterfly bolts but i suspect I could fall foul of certain shortcomings from our overseas manufacturers in terms of quality.
      Any suggestions welcome
      Chris
      Chris TickTock
        @christicktock
        #484110
          Saw a slot across a cap head screw, saw/file up a pleasing shaped head from steel sheet and silver solder into the slot
          another option is to take some steel bar, turn down and thread one end to the size you need and then saw off leaving sufficient to form a head. How hold by thread and turn the hean to an oval or round shape. mill the two sides flat and you have a thumb screw
          Edited By JasonB on 05/07/2020 16:37:52
          #484112
          Ian Parkin
            @ianparkin39383
            Chris
            so you want to convert a blade locking screw that you use an allen key for to a finger lock?
            use a m4 bolt as the post and use a m4 wing nut on it to use as the lock…if the wing nut or bolt wears out …replace it…?
            #484114
            Martin Kyte
              @martinkyte99762
              I would suggest you make a key. Retain the cap heads and make a key similar to a clock key with a suitable sized piece of hex from a cut down allen key driven into the pipe. Create a suitable holder on the saw for the key. A block with a hole in would be the simplest. You can make the key as wide as you like for ease and as long as you like for access.
              regards Martin
              Edited By Martin Kyte on 05/07/2020 16:43:03
              #484115
              Chris TickTock
                @christicktock
                Thanks Guys,
                The M4 bolt is basically pinching together a piece of steel with the far end threaded. Would a simple and effective solution also be to do what Ian states adding a butterfly nut to the steel bolt but use a strong loctite that stays in place such as retaining compound 680?
                Chris
                Edited By Chris TickTock on 05/07/2020 16:44:29
                #484116
                Chris TickTock
                  @christicktock
                  Posted by Martin Kyte on 05/07/2020 16:41:35:
                  regards Martin
                  Like it Martin, something I had not yet thought of.
                  Chris
                  #484118
                  Martin Cargill
                    @martincargill50290
                    Cross drill the head of the cap screws and drive a small roll pin through it to make a handle. You can put a larger roll pin over either end of the original roll pin in order to make the handle a little larger.
                    Martin
                    #484120
                    Ian Parkin
                      @ianparkin39383
                      Chris
                      just run a m4 bolt into the thread after putting a wing nut on the bolt
                      then use the wing nut to tighten it up
                      the nut does the same job as the bolt head
                      #484121
                        Whatever mods you do strength of the screw won't really come into it as your finger and thumb will never apply as much force as an allen key would unless you are built like Popeye.
                        Just buying a Tee headed allen key would be another option and give the same effect as Martin's suggestion.
                        #484125
                        Ian Parkin
                          @ianparkin39383
                          The thing about my suggestion is that you dont wear out the female thread in your equipment
                          the bolt shaft is replaceable when it wears out as is the wing nut
                          #484139
                          Chris TickTock
                            @christicktock
                            Posted by Ian Parkin on 05/07/2020 17:02:20:
                            Yes and this is probably the most pragmatic. Can I get M4 butterflies in strong steel? For this type of application is carbon steel essential?
                            Chris
                            #484142
                            Ian Parkin
                              @ianparkin39383
                              Chris
                              if it lasts even 6 months replace the screw or the nut a bag of 10 wing nuts will last a lifetime…guaranteed
                              #484145
                                Posted by Chris TickTock on 05/07/2020 18:02:53:
                                Chris
                                As I said above you will be hard pushed to strip an M4 wing nut using finder and thumb, if you are going to tighten it with pliers then maybe in which case whey change from allen key
                                #484146
                                Chris TickTock
                                  @christicktock
                                  Posted by JasonB on 05/07/2020 18:19:40:
                                  Chris
                                  I have just looked up the tensile and yield strength of A4-80 stainless v 88 steel and surprisingly not a heap of difference. I note it is easy to find more steel components in the states…we should support our steel industry but I had better watch it I'm becoming political. Thanks Guys..problem sorted.
                                  Chris
                                  #484152
                                  Robert Atkinson 2
                                    @robertatkinson2
                                    You can get moulded cps specfically to turn cap screws into "knobs"
                                    https://uk.rs-online.com/web/p/knobs/0771667/
                                    Other suppliers do them too.
                                    Robert G8RPI.
                                    #484212
                                      < deleted as irrelevant >
                                      Edited By Michael Gilligan on 06/07/2020 08:25:45
                                      #484235
                                      ega
                                        @ega
                                        Posted by Robert Atkinson 2 on 05/07/2020 19:07:03:
                                        Robert G8RPI.
                                        Thanks for the link. The economically-minded can easily make them, of course, and brass seems convenient for its relative softness.
                                        #484245
                                          Posted by Chris TickTock on 05/07/2020 18:25:39:
                                          Chris
                                          … I note it is easy to find more steel components in the states…we should support our steel industry but I had better watch it I'm becoming political. …
                                          Chris
                                          Nothing wrong with being patriotic but never ignore uncomfortable realities! One is that Brits would have to buy an enormous amount of steel to make a difference.
                                          In 2019, the UK made 7,200,000 metric tons of steel, about a million tons more than Holland, and slightly less than Egypt. At 87.9MT the USA was the fourth largest producer of steel in 2019 after Japan (99.3MT), India (111.2MT), and China who made a whopping 996.3 million tons, about half the worlds' steel (1869.9M) To put that in context, China made more steel in the last 3 years than the entire UK steel industry since the industrial revolution.
                                          Bringing British Steel up to Chinese levels would need every man, woman and child in the UK to buy about 16 tons each year forever, and they'd have to buy it whatever the cost. Producing that quantity of steel in the UK would require massive investment of money and land in steelworks, and seaports. It would very difficult to mass produce steel competitively because today most of the Iron Ore, Scrap and Coal has to be imported. Not much coal or iron ore left underground in the UK.
                                          Patriotism isn't the reason more steel products are available in the USA. It's simply there's a bigger market for them, partly 330Million people vs 67M, partly because of what they manufacture. In general, big markets result in more choice and lower costs, and the USA is big.
                                          British steel is unattractive to model makers for another reason. Like many other steel producing countries, Britain has shifted away from mass production of cheap carbon-steels into making high-quality alloy steels for specialised purposes. One example is railway lines where the steel must be strong, reliable, weldable and extremely wear resistant. Likewise special steels for lightweight bridges, pressure and corrosion resistant chemical plant, turbines, oil rigs and other highly demanding applications. These steels are expensive, high-quality and mostly useless in a home workshop.
                                          Supporting local industry and services may be good politics but always check the reality – emotional decisions are often expensive mistakes. I'm divorced!
                                          Chris TickTock
                                            @christicktock
                                            Posted by SillyOldDuffer on 06/07/2020 12:12:29:
                                            Chris
                                            Chris
                                            Informative stuff Dave, thanks for the post.
                                            Chris
                                            #484253
                                            Perko7
                                              @perko7
                                              Using a suitably long bolt, thread a butterfly nut onto the end until just fully engaged, silver solder in position, then cut off the head. I've used that process to make metric hex-head bolts in various sizes not available commercially. For most model engineering uses you will strip the thread before you break the silver solder bond.
                                              #484274
                                              Chris TickTock
                                                @christicktock
                                                Posted by Perko7 on 06/07/2020 13:18:22:
                                                Thanks for posting Perko, I like what you suggest and will note it for the future. this time i will go for Ian's method as in my opinion for this particular job it is best suited.
                                                Chris
                                                #484419
                                                Perko7
                                                  @perko7
                                                  yes
