Howdy
I have never soldered copper pipes together before ( but I have built a steam engine ) , and I'm creating a low pressure flash boiler and need to join some coils of 1/4" OD copper pipe together in series.
Now it makes sense to me to use a sleeve to join the pipes together ( to strengthen the join ) but didnt know if this was essential.
I think temps could be up around 300-400 C when in operation
(1) Should I butt join two pipes without using a joining sleeve
(2) Will silver soldering handle the temps or do I need to use something else?
(3) What type of solder should I use? I assume silver solder but wasnt sure of what % silver i needed in the solder and what type of flux etc?
(4) Do I need to use mapp gas or can a normal butane torch get hot enough for this type of work?
Any thoughts appreciated…..
Cheers
Steve
