Butane gas bottle adaptor
Home Forums General Questions Butane gas bottle adaptor
  • #22086
    mark reeve
      @markreeve78288
      mark reeve
        @markreeve78288
        Hi all, hope I'm in the right place, but this is my first posting, so be gentle.
        I currently do a lot of silver soldering using a mini, handheld gas torch. (Iroda PT-500). It has to be refilled from the little pressurised containers used to refill cigarette lighters etc, which proves quite expensive.
        I'm looking for a cheaper method of refilling the torch. As a caravanner I use two- 7Kg butane bottles and wondered if anybody knows of an adaptor that would allow me to refill my handheld gas torch directly from these?
        Hope you can help
        #89957
        Sub Mandrel
          @submandrel
          Hi Mark,
          I do the same for small objects using a 'cooks blowtorch' from Aldi which cost about a fifth of the same product as when it is sold for workshop use. The Range do one even cheaper.
          Gas used to be just £1 for a canister at tesco, but they don't sell it online anyomore. Not sure if they still sell it in store.
          In principle an adaptor would be do-able, although the challenge is to move liquid gas across – a more hazardous exercise.
          However, I understand that refilling from large vessels needs a licence.
          mark reeve
            @markreeve78288
            Hi Neil, Thanks for the information.
            I did try the Calor gas people, but they didn't respond.
            Will have a look in our local Tesco Extra Superstore and see if they still sell the cheap cartridges.
            Kind regards
            Mark
            #90019
            Clive Hartland
              @clivehartland94829
              I have always found the small canisters in the open markets, there is usually a chap who sells roll-up machines and papers and other assorted smoking apparatus. He will also advertise watch batteries etc.
              Usually pay a £1.00 for a can.
              #90021
              Roger Woollett
                @rogerwoollett53105
                The DIY sheds sell butane gas canisters for use with plumbers torches. They have a screw fitting.
                Bruce Engineering sell an adapter (£12.90) which I use to refil my small torch.
                Roger Woollett
                #90030
                Sub Mandrel
                  @submandrel
                  Hmm interesting calculation:
                  200ml of Ronson lighter gas is £1
                  635ml of blowtorch gas is £3.99.
                  So… £12.90 buys a more expensive way of filling the small torch. Perhaps an adapter to fill teh blowtorch with lighter gas is needed
                    Yes but the OP wants to use a 7kg bottle which costs about £20 to refil which works out at 28p/100mls.
                    And most blowtorch gas is a propane /butane mix so liekly costs a bit more and gives a longer run without presure drop.
                    J
