Burnerd Multisize Collet Chuck . .
Home Forums Manual machine tools Burnerd Multisize Collet Chuck . .
  • #45747
    WALLACE
      @wallace
      Hello all.
      I’ve got a Burnerd Multisize collet chuck which has either been dropped from a very great height or wasn’t ground correctly in the frist place as the run out on the end of the collet taper is a couple of thou.
      So the question is – how or where can I get is reground  ? (and not for totally silly money . . ).
      I should add that the spindle end is a L00 taper.
      thanks.
      WALLACE
      WALLACE
        @wallace
        #45760
        KWIL
          @kwil
          Sorry to see about your problem, the Multisize is a superb bit of kit as I have found.
          Have you tried contacting Pratt Burnerd? try msenior@600lathes.co.uk
          He is the contact point for spares and may well direct you.
          #46236
          WALLACE
            @wallace
            Thanks for the reply !
            I was going to email – but thought I’d have a bit more of a play around first. . .
            I turned a scrap piece of  1 1/4″ bar paralell and put the chuck onto this ‘ back to front’ if that makes sense – and measured the run out of the LOO taper end. And it was about 1/3 of a thou – so now I’m starting to think the spindle on the lathe isn’t true.
            Yet that appears to be the same – or possibly less. (Slightly diificult to measure around the full 360 degrees due to the locating key ).
            Finally, I started to wonder about the accuracy of the taper on the chuck – when ‘blued’ up, it only appears to make contact with the broadest part of the taper – there’s virtually none on the front part.
            All interesting (frustrating ? !) stuff !
            Out of curiosity – and something to aim for – does anyone know what should be the run out of say a 1″ precision ground bar held in the chuck ?
            W.
