Burglar alarm
Burglar alarm
Home Forums Electronics in the Workshop Burglar alarm
Viewing 25 posts - 1 through 25 (of 41 total)
  • #31936
    Speedy Builder5
      @speedybuilder5
      Remote alarm for garage / workshop
      Speedy Builder5
        @speedybuilder5
        I am building a garage which is remote from the house and mains electricity / telephone etc. I am devising a simple alarm system built around an old smart phone and a mains failure app (free of course).
        In essence, it will be a car battery topped up by a solar panel (also used for minimal 12volt LED lighting) which tops up the phone via the 12volt cigarette lighter charger for the phone. When the phone charger circuit is broken, the smart phone will send me an SMS message – at the same time, a normally open solid state relay will close and sound an alarm etc.
        A side benefit is that the Solar panel controller has a couple of USB sockets on it and that there will always be phone contact in case its time for coffee at the house. If the battery goes flat, at least I should get the SMS.
        BobH
        #345861
        Brian Sweeting 2
          @briansweeting2
          Good idea, make sure that you audible alarm complies with the regulations regarding length of time sounding etc. You don't want the council noise snoopers spoiling your day.
          #345880
          Samsaranda
            @samsaranda
            Your specification bears some similarity to the wonderful inventions of Heath Robinson, seriously though if it works it’s got to be good.
            Dave W
            #345885
            Martin Cargill
              @martincargill50290
              I bought a caravan alarm for my old lockup. Worked from a 12 volt battery and with its own sim card it could be switched on/off with its keyfob remote or by text message. If activated it could text 3 different numbers and phone the main number (so that you could hear the burglars at work!). It would also inform you of which circuit had tripped. It could also activate a relay to switch on lights and/or a camera, All for £130
              Martin
              #345886
              V8Eng
                @v8eng
                Posted by Speedy Builder5 on 13/03/2018 15:37:45:
                BobH
                I do not see any mention of remote disarming if there is a repeat false alarm and you are miles from home etc?
                That might be a consideration.
                Edited By V8Eng on 13/03/2018 18:10:47
                Edited By V8Eng on 13/03/2018 18:11:49
                #345889
                Speedy Builder5
                  @speedybuilder5
                  I don't think it will be a problem as the alarm has its own cutoff after a predetermined time.
                  #345893
                  I.M. OUTAHERE
                    @i-m-outahere
                    Would also make an interesting arduino project !
                    #346371
                    Howard Lewis
                      @howardlewis46836
                      As security, additional the 5 or 6 lever lock / hefty padlock, may I advocate fitting hinge bolts?
                      If the hinge pins are externally accessible, driving out the pins would allow the door to be lifted away from the striking plate. With hinge pins, this is much less of a possibility.
                      My door is a recycled fire door with a 6 lever mortice lock, but the hinge pins are just visible, externally. So anyone feeling strong could obtain entry in this way.
                      I made my hinge bolts by turning the heads off No12 woodscrews. The screws were screwed into the wooden door, using a drill chuck. The door was then partly closed so that the pins marked the door frame. Holes were than drilled on these marks, to act as sockets for the pins.
                      If you have windows, cover them, internally when not in the shop. If the lowlife cannot see what there is to steal / vandalise, they will look elsewhere, certainly if entry is going to be difficult.
                      #346375
                      pgk pgk
                        @pgkpgk17461
                        Sadly my experience with such devices..a hugely sophisticated multi-bell & light alarm system, cctv etc was that the neighbours ignored it, the criminals just rammed through the door wearing hoodies and gloves and caused more damage than they got in usable goods. They were gone inside 5 mins. Plod just issues a crime number and asks if you know who did it.
                        A bucket of dye above the door would be better since we're not allowed to wire in really effective tomb rader type traps…..
                        #346380
                          @mike89748
                          When I first started reading ME, I think some time back in the 1960s, there was a letter from a chap who got totally fed up with break-ins at his workshop, which was in a rural location. His answer was to buy a redundant electric factory hooter, and wire it to an alarm system so that most of the sound was directed inside the building. I seem to remember that the first low-life to break in ran straight through a glass window in his hurry to get out, and the second was led out, a gibbering wreck. After that, word got around and the break-ins ceased. Pity you couldn't get away with such a trick these days!
                          Edited By Mike on 16/03/2018 17:54:43
                          #346385
                          michael howarth 1
                            @michaelhowarth1
                            Posted by Mike on 16/03/2018 17:49:48:
                            Why not?
                            Mick
                            #346395
                            Muzzer
                              @muzzer
                              Wouldn't you be better off with a couple of webcams covering the entrances and access road? More likely to be deterred if it's clear you are being recorded. These modern cameras store the video and stills on the cloud and can also send texts (movement detection etc) and allow you to view the feed etc. If you have mobile coverage as you say, the cost of data is peanuts. Loads of people make them nowadays, a sort of fusion of connected / smart home appliances and intruder alarms. Bells and lights won't stop them but you might either deter or identify them – or at least filter out the real lowlife vandals who do most damage.
                              Murray
                              #346396
                              vintagengineer
                                @vintagengineer
                                These are very effective! https://www.youtube.com/watch?v=4D_3nAfmcqY The other deterrent to use MIG wire stretched across the workshop just above ankle height.
                                #346402
                                mechman48
                                  @mechman48
                                  My garage/ workshop conversion is attached to my bungalow & after being burgled back in 2014 I have installed a separate alarm system that has PIR motion detector plus magnetic contacts on the entry door, the advantage of this system is that when the alarm goes off ( tested ) it gives out a very loud 'wow wow' within the garage itself, way above the decibel level that the human ear can tolerate, plus extra lateral bolts in the roll up door very similar to Mike's posting,… fingers x'd, so far, so good.
                                  ​George
                                  #346406
                                  the artfull-codger
                                    @theartfull-codger
                                    I have 4 night & day cctv cameras that cover our yard and out buildings barn & workshop,but if they want to be in they will, you can only do your best to protect things,I got turned over a few yrs ago & lost a couple of thousand pounds worth of equipment[pre camera days] the theiving scrap men they probably got £30 for the lot also got a couple of burglar alarms too, cops gave me a crime number and asked if I wanted "counselling" hmm.
                                    #346412
                                    FMES
                                      @fmes
                                      Got one of these wired up to the alarm internal sounder **LINK**
                                      Luvly
                                      Lofty
                                      #346418
                                      Mike Poole
                                        @mikepoole82104
                                        My youngest son has trouble getting up in the morning, I decided to wake him up with an industrial Yodel alarm, it did wake key him up but he yanked the supply out of the alarm(24V) 120dB may be a bit excessive in your bedroom.
                                        #346421
                                        peak4
                                          @peak4
                                          A friend of mine was recanting a tale about one of his biking friends.
                                          Apparently their shed alarm went off, triggering a text to his mobile and the arming of the web cams and recorder.
                                          A couple of local scrotes in the shed got something of a surprise, when householder started shouting something about armed response, and chucked a thunderflash in their general direction.
                                          There was further damage as well as the shed though, since one of them ran clean though a larchlap fence panel in an effort to escape.
                                          All caught on video, and reckoned to be most amusing to watch. devil
                                          Until I wired it up to the house alarm, my garden workshop housed a 10" fire alarm sounder inside the shed, which made a bit of a din.
                                          Edited By peak4 on 17/03/2018 00:18:54
                                          #346422
                                          Maurice Cox 1
                                            @mauricecox1
                                            With reference to the hinge pins that Howard mentioned, another way to thwart the removal of the hinge pins, or indeed the hinges themselves, my shed has three hinges, and in line with each is a stout plate that overlaps the doorframe when the door is closed so that the door will not come out of the frame.
                                            #346442
                                            Bazyle
                                              @bazyle
                                              Some more ideas on security on this website.
                                              #346507
                                              Stuw
                                                @stuw95558
                                                Don’t forget to put a warning sign on the door at about eye level to complement the good stuff, “ watch out for snakes upon entry” in clear stick on letters, put Ikea black roll blinds at the windows, and outside bars are good held in place with decent sized round head coach bolts through the frames, good luck.
                                                #346537
                                                Gordon A
                                                  @gordona
                                                  What about having 2 or more independently powered sirens hidden inside the shed or workshop? Therefore if one siren was found and disabled, it would be too painful to stick around finding any more.
                                                  If this was the case, would an EU approved sign on the door, warning of loud noises be required in order not to fall foul of UK law?
                                                  Gordon.
                                                  #346616
                                                  Stuw
                                                    @stuw95558
                                                    What Eu sign? In my yard I am the maker of rules not the EU, my sign warns them to look out for snakes, a bit of information which shows the seed of fear into their punk scrote hides.
                                                    #346619
                                                    Journeyman
                                                      @journeyman
                                                      You are of course assuming said scrote can read devil
