Bronze or brass
Bronze or brass
Home Forums 3D Printers and 3D Printing Bronze or brass
Viewing 15 posts - 1 through 15 (of 15 total)
  • #565316
    Dalboy
      @dalboy
      I know this is possible a difficult question to answer but sorting out my metal stash which most of it was left over from other projects I found an hexagonal piece of brass (On the right in the photo, I also found this other piece which by the colour of the oxidized part is more of a bronze colour.
      I turned down a small portion of each piece and there is a definite difference of colour again very much a bronze colour compared to the hexagonal piece.
      I suspect that I brought it to make some small prop shaft bearings many moons ago but memory fails me
      Could I be correct in my assumption
      Dalboy
        @dalboy
        #565317
        noel shelley
          @noelshelley55608
          One test would be to take a small sample and heat to well above melting point ie 1050c ! at this point if brass the zinc will fume or burn off – avoid breathing the fumes ! Noel.
          #565320
          pgk pgk
            @pgkpgk17461
            A quick punt about google came up with the link below..could be useful but admittedly the zinc test would be awkward:
            https://manual.museum.wa.gov.au/book/export/html/157
            pgk
            #565325
            Dave Halford
              @davehalford22513
              Doesn't brass change colour when put in an acid pickle due to the surface zinc being dissolved and bronze stays the same?
              #565339
              Baz
                @baz89810
                From your photo I would say round is bronze and hex is brass.
                #565341
                Buffer
                  @buffer
                  Derek this wont help this time but I always stamp the end BZ, PB etc when I buy stuff. Just got to make sure you saw off the correct end!
                  #565342
                  Dalboy
                    @dalboy
                    Posted by Buffer on 03/10/2021 13:47:54:
                    With the new stuff I have brought recently I have done exactly that so all of my Ali has been stamped.
                    #565343
                    Dalboy
                      @dalboy
                      Thank you all but at the moment don't have the items to be able to do some of the tests. I realize it was a long shot but from my time as a plant mechanic and have dealt with bronze bushes everything was pointing in that direction but that was before 2003 when I had to pack up work
                      #565495
                      Phil H1
                        @philh196021
                        Machining might be another indication?
                        For me, brass forms tiny irritating, short, sharp chips (irritating when they manage to get in your socks). Bronze that I have used always seems to form longer, ribbon type chips.
                        Phil H
                        #565508
                        KWIL
                          @kwil
                          Agree RH is brass, LH is bronze. Surface striation of the LH is typical of bronze bar but not definitive.
                          #565536
                            Posted by KWIL on 04/10/2021 13:49:04:
                            ^This.
                            Dalboy
                              @dalboy
                              Again thank you all. Not sure of grade of bronze which I know no one will be able to say but it certainly machined nice as well as easy
                              #565546
                              Bazyle
                                @bazyle
                                Polish the end in the lathe and dob on a little vinegar. It will quickly show the crystalline structure of brass, but have far less effect on bronze. Use pieces of known material for comparison.
                                #565554
                                JohnF
                                  @johnf59703
                                  My guess is Gun Metal which is in the Bronze family of copper alloys — only a guess but the colour and un-machined surface looks like GM to me
