Have you tried the dodge of taking the rake off the drill cutting edge? For turning bronze we use zero or negative rake tools, the same actually should apply to drills. What you do is stone away the spiral behind the cutting face. It doesn't take very much to make them stop grabbing. You don't need to touch the actual end of the drill.
Of course a drill you have treated like this is no longer quite so good for steel, although they will still work, however it is better to modify a drill that is kept separate for brass and bronze, preferably a few in a few desired sizes.
It could be LG2 bronze, which often comes with spiral marks on it. That is made and sold for making bearing bushes.
Edited By John Olsen on 11/01/2019 04:05:21
