Hello all
Right thank you all for the reply's, I won't be changing the balls then! It was just my thoughts, I asked for peoples mechanical opinions on the change, not for more reply's about insurance than what I actually asked (I doubt my insurance company would even know what I was on about if I told them down the phone!) Like the last post I also see insurance as the biggest con going but thats my opinion.
ICS I have been in contact with the prices arent exactly cheap but I did say in my original post I have no problem with that, I was just looking in to improving the longevity of the remidial work done. Thanks for the info on ball screws manfactures, definatly something to look in to, I hadnt actually thought about them. However using larger balls is not possible as they have to travel though a tube on the nut so it would requre a lot of re-work. The actual worm shaft is welded up out of 3 pieces.
I did not criticise the original design of the land rover steering, so why some people seem to think I want to totally redo the steering with a rack etc I dont know. Thanks for the suggestions but maybe read what I wrote in the begining again. The fourtrak point has been noted, however they seem to be at about the same cost as land rover stuff for a good one so I will probally just save all the hassle of redesigning the system and just keep it original.
My land rover is a 1963 2a diesel, 2 owners from new, within a 15 mile radius of each other in Devon, It was almost a shame to bring it over to Kent but hey ho! Being a 63 it should have the wire spoke, pinch bolt clamp type wheel. mine doesnt it has a series 3 box and wheel, the steering lock facility is the biggest giveaway. this box appears to have been second hand when installed itself so the wear had already taken place, I think then a poor set up and adjustment when installed has caused the damage. the original owners manual doest exactly say when to change the oil, it just say to cheack it at regular intervals, im not sure what the service manual says as it not close to hand at the minute.
I have managed to source a genuine NOS worm and nut for both the correct type box and my series 3 box. I will rebuild this and use it untill, I find an early wire spoke wheel so I can return it to stock if I also can find an early box in the future.
Thanks for the importance of setting the swivels, I wont touch them as they feel fine at the moment. I plan to overhual the axles next year so will address them then.
Thanks again for the help
William
