Bronze
Bronze
Home Forums Materials Bronze
  • #766087
    Garry Coles
      @garrycoles69390
      Hi,
      Many years ago I acquired a 4ft X 1in length of bronze !!! propeller shaft from a boatyard. I thought that this would come in handy for the various steam fittings for the many models I have built over the years. However, I have just found out that my very strong magnet has a slight attraction to it, not the full monty like it does with steel. The magnet that I usually use does not attract to it at all. There is no sign of corrosion on the surface at all. Can anyone enlighten me to the content of what might be used in old propeller shafts.
      Garry
      mark smith 20
        @marksmith20
        Its notunknown for some bronze to have tiny amounts of iron or nickel present .
        #766092
          The Aluminium Bronzes often get used for marine aplications and do contain iron see chart for (Fe)
          #766154
          Nigel Graham 2
            @nigelgraham2
            Though note that aluminium bronze is not the easiest alloy to join by soldering (soft- or silver- ).
            #766277
            duncan webster 1
              @duncanwebster1
              And it’s a pig to drill
              #766526
              Mick Bailey
                @mickbailey28509
                When my bronze offcuts get mixed up I identify the aluminium bronze using a neo magnet to detect any attraction of the nickel content in the material I use for valve guides.
              Home Forums Materials Topics
