Hi Guys,
Circlip is right with the dissolve method being effective,(you see we can agree on some things), but of course it depends on what the broken tap is stuck in.
I recently, well last year come to think of it, broke a M2 tap in some Aluminium, bu**ered if I was going to make a new part, if I didn’t have to, so, I used some “cartridge case cleaner”. This is a dilute Nitric acid based solvent and ate the tap in about an hour, leaving a mucky black sludge and once washed a nice clean hole. If in doubt about dissolving the parent metal try a sample first, but C.C.C.should be OK in brass and copper, as well as Alloy. Iron and Steel would be a bit of a problem.
H&S rules may have changed since I bought mine at a ME exhibition, from he guys who sell metal blacking kits. If your paranoia says “mustn’t touch acid with a barge pole” don’t break taps!
chris stephens
PS the name on the bottle is Delway Technical Services with an 0151 phone numbe, I expect Goggle will find them if you are interested.
