Broken tap
Broken tap
Home Forums Beginners questions Broken tap
  • #60006
    Dave C
      @davec87625
      Help after spending a long time making a particular part I have managed to break a 1/8 x 40 tap in the thing, Apart from the lesson learned of doing the tapping as early on as possible before all the easy shaping etc I would also need some help to get the thing out again.
      The tap is about 3/16″ deep and is HSS (I think) into BMS
      I really dont fancy making another full part so if there are any Ideas for me to try first it would be greatly appreciated ! !
      Dave C
        @davec87625
        Broken Tap help please
        #60008
        GERALD EDWARDS
          @geraldedwards97099
          DO WHAT WE DO AT WORK  GET CARBIDE CUTTER AND USE IT AS A DRILL FAST 1000RPM+ STEADY PRESSURE IT GOES THROUGH LIKE BUTTER IF YOU HAVE AIR LINE BLOW ON IT THEN PLUG THE HOLE AND REDRILL AND TAP IT
          #60010
          Dave C
            @davec87625
            Now for the next beginers question. You say carbide cutter but what profile etc should I use as I have never attempted this before.
            Many thanks
              Carbide 2 flute slotdrill as these are endcutting.
              Sometimes you can pick them out with teh end of a scriber or a couple of hard pins down the flutes and a small rod between to act as a tommy bar, does depend on how tight the tap is stuck
              Jason
              Edited By JasonB on 05/12/2010 19:31:04
              Edited By JasonB on 05/12/2010 19:32:41
              #60013
              Ramon Wilson
                @ramonwilson3
                There is a home produced alternative David, especially as the tap is not too deep.
                You could make a hollow cutter from silver steel and providing you can position it accurately over the axis of the broken tap you can mill the metal from around the outside.
                The OD of the cutter should be as small as you can get away with perhaps 5mm in this case. Cut the teeth with a triangular file and H&T. It is a slowish process but by it’s nature quite controlled. As you are quite shallow you will probably not have to go far before the tap will loosen. The cutter does have to be continually withdrawn to clear the swarf and of course it does leave a larger hole. Don’t debur this hole.  Loctite in a small slug and peen it over then machine off before re-drilling – possibly you still have plenty of depth of  the original hole left to take the strain.
                I have used this method – it does work and has it’s drawbacks as stated but you need nothing more than a bit of silver steel and the means to harden it.
                Good luck which ever way you choose – it can be a very awkward set back but not unsolvable.
                Hope this helps in some way,
                Regards – Ramon
                #60015
                Sub Mandrel
                  @submandrel
                  If you have some 3/16″ to 1/4″ silver steel, drill a bit out 1/8″ and file some cutting teeth on the end. Harden and temper and use it to carefully drill out the material around the tap. You can then plug the hole and try again.
                  GERALD EDWARDS
                    @geraldedwards97099
                    JUST A NORMALY CARBIDE 3 FLUTE SLOT DRILL WE USE MR CUTTERS I WOULD NOT GO UNDER 4 MM DIA
                    #60017
                    GERALD EDWARDS
                      @geraldedwards97099
                      MAKE SURE DEAD CENTRE OVER THE BROKEN TAP
                      #60044
                      Dave C
                        @davec87625
                        Thanks for all the help guys, Its very much appreciated !
                        MICHAEL WILLIAMS
                          @michaelwilliams41215
                          Snapped 4BA Tap
                          By Peter Bell
                          Topic: Workshop Techniques
                          15 717 16/10/2010 13:29:46
                          By MICHAEL WILLIAMS
                          Find this earlier thread – there is a lot of useful information by various different people .
                          (Thread on p6 of list when I looked today)
                          Edited By MICHAEL WILLIAMS on 06/12/2010 10:59:47
                          #60050
                          Terryd
                            @terryd72465
                            Thanks for that tip Ramon and Stub,
                            Doh!  After all these years of broken taps and scrapped work I never thought of the obvious easy and cheap solution, especially if the plug can be soft soldered in, I’m of the old school and just don’t seem to be able to trust glue!
                            Hi Gerald,
                            Just a word of advice, All capital messages are considered rude on the internet (and in emails) it is considered to be the equivalent of shouting at someone.  On some forums it would not be acceptable.
                            Best regards
                            Terry
                            Edited By Terryd on 06/12/2010 11:05:05
                            #60059
                            Ramon Wilson
                              @ramonwilson3
                              Hi Terry
                              Yes so was I until I tried it buuuuuut…. ‘you need the right type in the right application with the right clearances’ for it to be at it’s best
                              For most occasions that I use it in preference to solder, either soft or silver, it’s because no heat is required but like so many other things ‘yer pays yer money’ etc. I can say though that where I have used it so far over several years it is, as yet, to let me down – I suppose it can’t be said fairer than that.
                              (BTW Haven’t forgot the pics – just doing something at the mo will send them when finished)
                              Regards – Ramon
                              #60063
                              Johan van Zanten
                                @johanvanzanten
                                Hi Dave,
                                I can spark erode the tap for you. Most of the time the work has no damage and you can just schrew a bolt in the hole. I will do it for free but you have to sent the pice to the Netherlands. Perhaps I hear from you.
                                Regards,  Johan.
                                Edited By Johan van Zanten on 06/12/2010 16:17:16
                                #60068
                                James fortin
                                  @jamesfortin46829
                                  i once read that spark erosion was partly discovered in the russian ship yards as they used to weld an extra piece of bar to a broken tap or drill and unscrew it via the welded piece, but they noticed that when they welded it the spark eroded the metal and so EDM was born.
                                  you could try zapping a rod to it with a welder?
                                  many thanks
                                  james
                                  #60093
                                  James Fair
                                    @jamesfair36731
                                    This comment may be too late now, but in the aircraft maintenance trade, we have what is called a ‘tap remover’. There are four steel fingers attached to a T-handle, and a sliding collet which surrounds the fingers. In use, the fingers are inserted into the flutes of the tap, and the collet is slid down to capture the fingers as close to the tap as is possible. Then the fun begins; twisting and rocking on the T-handle and not over-torquing the thing will usually get the tap to back out. A bit of heat on the part, a bit of lube, a bit of patience. If the steel fingers twist off, you’ll have to get them out and then try again. If the tap is a three-flute model, there are three-fingered removers to match. These can be shop-made as well.
                                    All the best on that.
                                    Jim Fair
                                    #60097
                                    Dave C
                                      @davec87625
                                      Re your extremely generous offer Johan. Many thanks indeed for your more than generous offer off help removing the tap. I have after a combination of efforts now finally removed the tap though not as cleanly as I would have liked. There was very little clearance around and below the tap to work with and so I may end up making a new part after all. I now wish I’d have logged on again sooner as I would have gladly accepted your offer of help.
                                      I think this one will be put down to experience however I now know what to to in the future,
                                      Many thanks to all for advice and assistance.
