Bright steel
Bright steel
Home Forums General Questions Bright steel
  • This topic has 29 replies, 16 voices, and was last updated 5 May 2023 at 17:40 by mark costello 1.
Viewing 25 posts - 1 through 25 (of 30 total)
  • #643801
    Stephen Follows
      @stephenfollows82099
      I have bought some bright steel to make tool makers clamps. Problem is I can't cut a thread in the stuff. Good quality taps used, correct size holes and even tried oversized holes but no joy. Years of cutting threads but not had this problem before. Steel is dulling new, unused taps.
      Anyone had this problem? I have read another post where it was suggested that the holes were the wrong size r the taps were blunt. No so in my case.
      Stephen Follows
        #643802
        Alain Foote
          @alainfoote90915
          Stephen are you using a tapping compound e.g. Rocol RTD? Especially helpful if it’s stainless steel or gauge plate etc. What size thread/pitch/thread form? What is the material grade?
          Alain
          #643806
            Sounds like work-hardening.
            A mistake maybe? Someone thought 'bright' meant a shiny stainless steel was wanted rather than Bright Mild Steel.
            If it is a work hardening stainless steel the taps may be blunt now.
            Stephen Follows
              The steel is definitely not stainless. I was trying to tap 5/16" BSF, 24tpi.
              #643813
                HSS tool blanks are also bright and steel, without knowing what you bought its a bit hard to say. Did it saw and drill OK?
                #643817
                bernard towers
                  @bernardtowers37738
                  Try the spark test on your bench grinder
                  #643819
                  Clive Brown 1
                    @clivebrown1
                    Doesn't have to be stainless steel to be tough on cutting tools. Steels with a fairly high manganese content can be as well. It's what they make prison-cell window bars from! ( No good smuggling in a hacksaw blade).
                    #643830
                    Dave Halford
                      @davehalford22513
                      Posted by Stephen Follows on 03/05/2023 17:28:49:
                      The above would imply not mild steel, it's a bit bendy, did you tell the supplier what it was for?
                      #643835
                        Not sure what would imply that the ones I made at school were bright mild steel and still going strong.
                        #643855
                        Stephen Follows
                          Hand cut ok with hacksaw. Milled ok but seemed to be a bit harder than usual to drill.
                          #643857
                          Bill Phinn
                            @billphinn90025
                            Stephen, the way it works is that if you want to know a material's machinability you need to know exactly what it is. "Bright steel" (sic) could be one of countless different steels. "Bright mild steel" would bring us closer, and EN1A, for example, would more or less nail it.
                            If your supplier didn't give you a code such as EN1A and, what's worse, described it merely as "bright steel", it's impossible to say exactly what it is you're trying to machine and why it's causing you problems.
                            #643864
                            Stephen Follows
                              It’s described as bright mild steel. No numbers.
                              #643871
                              Dave Halford
                                @davehalford22513
                                Posted by JasonB on 03/05/2023 19:49:46:
                                I made some pliers at school, case hardened jaws and 1/8" handles with a twist near the jaws, they looked great , but boy did they bend .
                                #643872
                                duncan webster 1
                                  @duncanwebster1
                                  I wouldn't buy any steel without a spec. If it's a ME supplier he bought it from a stockist, so should know what it is. If supplier won't tell you what it is go elsewhere. Good Commercial Quality means they've lost the cert.
                                  #643873
                                  Bill Phinn
                                    @billphinn90025
                                    Posted by Stephen Follows on 03/05/2023 23:02:11:
                                    Working on the assumption for now that it should be readily machinable with good quality drills and taps, what are your taps exactly, i.e. brand and type? Are the holes blind or through holes? How deep? Can we see an image of a now dulled tap and a hole it struggled with?
                                    You say you're trying to thread 5/16" BSF x 24 TPI. But 5/16" BSF is 22 TPI.
                                    #643880
                                    Hopper
                                      @hopper
                                      What brand of taps are you using? Sometimes you get a duff shipment that are not correctly manufactured or heat-treated.
                                      Try drilling and tapping a hole in a piece of known mild steel that you have machined before without problems. If it taps OK, then your problem is the bright steel stock you bought for the toolmakers clamps.
                                      #643902
                                      Brian Wood
                                        @brianwood45127
                                        As a suggestion, try heating to a dull red heat and let the material cool as slowly as possible buried in something like vermiculite. That will certainly alter the crystal structure and it might be enough to let you get on with making your clamps
                                        Regards Brian
                                        #643905
                                        Stephen Follows
                                          Apologies, I was initially trying UNF which is 24 tpi. Drilled a new hole After tap ruined and tried BSF.
                                          #643910
                                            Posted by Stephen Follows on 04/05/2023 10:27:56:
                                            Easily done! If only there was a single standard system thread system that did away with BA, BSW, USS, UTS, BSF, BSC and others.
                                            Oh there is – metric!
                                            I shall be hiding in my bunker for the rest of the week…
                                            Stephen Follows
                                              You're right SillyOldDuffer. Unfortunately, before you know it someone will want to split metric into coarse and fine….
                                              #643917
                                              Nick Wheeler
                                                @nickwheeler
                                                Posted by Stephen Follows on 04/05/2023 11:22:03:
                                                Let 'em.
                                                You don't have to for your own stuff…
                                                #643918
                                                Hopper
                                                  @hopper
                                                  And there are ISO metric threads, DIN metric threads and JIS metric threads…
                                                  #643920
                                                  Nick Wheeler
                                                    @nickwheeler
                                                    Posted by Hopper on 04/05/2023 11:28:09:
                                                    Surely the threads are the same, but less important things like the size of the heads/nuts change?
                                                    #643964
                                                    Anonymous
                                                      Posted by Nick Wheeler on 04/05/2023 11:30:00
                                                      Surely the threads are the same…
                                                      Not necessarily; M3x0.6 is used in Japan, and to some extent the US.
