In another thread there's a warning that Bright Mild Steel might warp after machining. This is supposed to be due to stress relief after cold rolling and the advice seems sensible.
Thing is I often use Bright Mild Steel and have never had a problem with warping. Looking Bright up on the web I found this advice from a supplier, my bold:
Bright drawn mild steel is an improved quality material, free of scale, and has been cold worked (drawn or rolled) to size. It is produced to close dimensional tolerances. Straightness and flatness are better than black steel. It is more suitable for repetition precision machining.
Bright drawn steel has more consistent hardness, and increased tensile strength.
Bright steel can also be obtained in precision turned or ground form if desired.
Now I'm wondering. I've not had a problem and here's a vendor recommending it for precision machining. Have others had lots of bad experiences with Bright Mild Steel warping, or is machining it low risk in practice? Using Bright rather than Black saves a lot of time.
Also, complaints about poor quality steel are common on the forum; could this be down to it being of the Black variety? None of the Bright Mild Steel I've bought has been of poor quality.
Thanks,
