Posted by Harry Wilkes on 17/08/2023 16:21:04:
Purchased some 0.125" bright mild steel round I find it to be 0.117" I understand that I may have been supplied 3mm, but lets say it is imperial what sort of tolerance should I expect ?
H
I can't find any tolerances for Bright Imperial Round Drawn under 1/2" diameter, which is -3 thou to 0.0
Bright Metric Round Drawn under 6mm diameter should be -0.07mm to 0.0
What you have is certainly in spec for metric 3mm, and given Imperial doesn't seem to specify tolerances below 1/2", it could be street 1/8" too! Bet its 3mm though.
