Rick
Yep 1979 model.
I have wiring diagram WD148D in pdf format. PM me your E-Mail and will send it over.
VFD fitment is pretty simple. Basically strip all the control gear and control everything via the VFD. Preferably with a remote box.
For pump and powerfeed drive connect the transformer for 240 volt input.
You can set things up so the VFD controls are linked to the original push buttons and contactors but most folk don't bother as there is no real gain. The VFD is still direct to the motor.
Do you yet have a VFD?
If not I have a VFD and pendant box off a converted Bridgeport that I should really sell on.
Planned to use is as part of a conversion from Varispeed pulley drive to direct two speed belt drive. But the "terminally broken" level noises from the varispeed turned out to be anything but. Simple mechanical fix of an "I didn't know that could happen" type problem. Much easier than re-engineering the drive.
Edited By Clive Foster on 04/12/2022 19:42:31
