Bridgeport J Step Pulley Spindle Motor
Home Forums Electronics in the Workshop Bridgeport J Step Pulley Spindle Motor
Viewing 2 posts - 1 through 2 (of 2 total)
  • #380364
    Gavin Bell
      @gavinbell14486
      Hi,
      I'm nearing completion of mechanical restoration of an old J with stepped pulley. It has the very old original table feed motor.
      My Harrison M300 is powered by a Drives Direct D type step-up 240 to 415V inverter and I have wired so that all the original lathe controls and switches are ultilised.
      Of course, now I realise I probably have to shell out another £500 for another inverter to run the Spindle motor on the Bridgeport (2 speed with reverse – 5 switch positions) as I don't believe it to be dual voltage. The feed motor is dual voltage so can be powered by a simple inverter for £100. (I must say, given the age and weight of the table feed motor, I'm likely to change that to a modern unit at some time….it must be bending the table…)
      I've searched and read dozens of threads on similar topic but am left looking for a financially less hurtful solution, which may come from :
      1. replace spindle motor with a dual voltage item that can run 240v 3 phase and use a low cost inverter
      2. use a rotary converter and power the whole machine with that, as if hooked into a mains 3 phase supply
      3. Try something like a Clarke static converter
      My preference is probably 1.
      I don't mind stripping a motor to extend the shaft if required if a suitable motor type could be identified.
      Thanks in advance for any pointers
      Gavin
      Gavin Bell
        @gavinbell14486
