@Jez, I managed to get the wiring all sorted out and powered up the machine for the first time yesterday, the work lamp shone brightly, the DRO glowed warmly but that was all she wrote. It was getting later in the evening and decided to sleep on it.
Woke up this morning with the idea in my head that the problem must be in the power supply to the control box (motor, table, pump control) That control box has a nice big green button and red e-off switch – push for off but twist to release and reset. I had already checked that but I had a suspicion that the e-off wasn't releasing properly. A quick squirt of contact cleaner and a bit of a wipe and now it works as it should, everything powers up and works as it should. I bought the machine knowing at had a "noisy head" – the guy wasn't kidding, it rattles and clanks like a ghost train. So my next job will be to strip and rebuild the head. You mentioned in your earlier posts that parts for SEMCO (Long Chang clones) are not all compatible with genuine BPs, did you source replacement parts from SEMCO direct? (I bought the operators manual and wiring diagram from them, I also bought the Guide to Renovating the Bridgeport 2J, an excellent book).
Cheers,
Jason
