I fitted a Bridgeport 2j vari-speed head to my Tom Senior mill during the summer. The head is a heavy old lump, about 180lbs so no way i could lift it by myself and my shed to too low to use a hoist or lifting gear.
So i split it into two separate pieces, the upper and lower. Having now got the whole thing back together, aligned, trammed etc, and i am starting to run the machine, there is an issue with the speed selection of the spindle.
It is controlled by a handwheel which you wind in either direction to raise or lower the speed. I do not know how to adjust this particular feature, there is no mention in the manual.
Would anyone happen to know how to do this correctly ?
