Thank you for all the constructive comments, and even a thank you for the off beam comments
I used the diode test setting on one of my DVMs for the first time in my life (!). The new rectifier gave 0.570, 0.574, 0.567 and 0.578 v across the four diodes and OL in the other direction. The old four plate/ five tapping rectifier gave 0.185, 0.330, 0.221 and 0.185 v, and OL in reverse – so I guess that was a germanium one?
So my old rectifier was probably still working and I was wrong to assume it had failed. The assembled charger was connected to a 12v 12w bulb and it lit ok, but when connected to a 12v 60w bulb the overload trip kept triggering. Ah Ha I thought that is the problem, so I bypassed it with a cable. Now the charger will light the 12v 60w lamp, but it was only delivering 3A, and it should be 5A.
So, I put another ammeter in series and confirmed it was only delivering 3A. I put a voltmeter across the lamp and noted the following:
Switch 12v; switch Hi; voltage = 8.8v
Switch 12v; switch Lo; voltage = 7.3v
Switch 6v; switch Hi; voltage = 5.0v
Switch 6v; switch Lo; voltage = 4.1v
The voltages are in the right order but all about 60% of what they should be. Nothing was getting hot or smelly, except the heat sink on the rectifier that was warmish. Unless I have one plug socket in my workshop that delivers 140v AC I can only presume that a winding has failed in the transformer.
I don't really understand how a winding can fail yet I still have circuit continuity and the ability to deliver 3A. Perhaps a winding has blown and shorted to itself, thus reducing the number of turns on the output by 60%, thus reducing the voltage. Have I got that the right way round?
Looks like it will have to go to the great scrapyard in the sky and I will have to buy a new plastic one.
Edited By norm norton on 17/03/2016 17:11:40
