OK here goes!
I would love to build a steam engine, but no money, time or facilities has made that highly improbable.
A couple of years ago I came across a couple of videos on youtube which I thought were steam engines but subsequently turned out to be Hot Air Engines. A bit of research and I was hooked.
Cheap, no expensive tools required, no high pressure steam – with many examples being made out of recycled paint cans and the like and can be made on the kitchen table.
When I started out I did not have any stainless steel paint cans, but I did have a few feet of 2.1/2" copper pipe.
Stirling engines have a sealed cylinder, one end of which is heated, the other end is cooled. I chose to build my cylinder in copper but with a thermal break between them to prevent the heat transferring quickly from one end to the other.
To join the two ends of the cylinder together I used a clamped / flange connection that I developed for a previous project.
The former for making the flanges I made in a hotel bedroom in Abu Dhabi cut from a nylon chopping board using an electric drill, coping saw and a file. No work bench just a glass topped coffee table. It was done to pass the time away on a boring contract.
Edited By Brian Rutter on 24/06/2020 15:05:09
