Brian’s 1″ Minnie Traction Engine
Home Forums Traction engines Brian’s 1″ Minnie Traction Engine
Viewing 25 posts - 176 through 200 (of 334 total)
  • #294226
      Good sliding fit, I think I have the O ring sizes somewhere, will have alook tonight. Think I got them in a set for the minnie from Reeves when I made mine.
      Brian Abbott
        @brianabbott67793
        Thanks Jason.
        Fingers cross i have the bore exactly true and perpendicular to the face that mounts the front flange sad.
        #294650
        Brian Abbott
          @brianabbott67793
          Hello,
          When i turned the liner on my minnie cylinder i left it about .001" undersize.
          On rechecking now its fitted i have a slight taper, measures 0.624" at one end to 0.625" at the other.
          Very annoying, the finish is really good and the plan was to give it a quick polish to remove the last little bit.
          Do you think lapping would true this up ?
          Thanks.
          #294672
            How are you measuring it Brian? I'm assuming something like a bore gauge than measuring over it with a calipers or micrometer.
            Unless you use something that reads to a tenth of a thou. The actual taper could be well below a thou but just happens to straddle the line betwee 0.624 and 0.625. On the other hand it could be nearly 2 thou, but that would probably appear obvious.
            As long as your piston doesn't jam at one end or slop at the other, the o-ring should cope with a taper of about a thou.
            Brian Abbott
              @brianabbott67793
              Hello Neil, thanks for the reply.
              Yes, using a spring bore gauge with a micrometer.
              I think i will turn a gauge to pass though the bore to see exactly what is happening and if there is an issue
              maybe i could try and pierce of 1200 grit paper on a split mandrel to lighly polish the bore ?
              Jason..did you have any luck findind the o-ring size for the piston ?
              The closest i can find is a BS111 which has an id of 0.424" and an od of 0.630"
              Thanks
              #294695
                BS111 is the correct size for a 5/8" / 0.625" nominal bore.
                They have to be oversized by a few thou as they should be compressed when you insert them – that's why they can accommodate slight tapers.
                Richard S2
                  @richards2
                  Posted by Brian Abbott on 23/04/2017 21:01:15:
                  Hello,When i turned the liner on my minnie cylinder i left it about .001" undersize.
                  Do you think lapping would true this up ?hanks.
                  Hello Brian, I had a similar dilemma with the bore, and unsure of the standard of finish necessary. I decided to polish it to size and finish by lapping anyway and before drilling any ports into it.
                  I made a brass lapping tool about 2" (50mm) in length and as true to 5/8" dia and parallel as poss with shallow grooves spaced 3/16" apart along the length to carry an abrasive (T-cut original) mixed with White Spirit.
                  It took me a few hours, but the results were excellent and allowed me to make the piston a real good smooth fit.
                  #294746
                  Brian Abbott
                    @brianabbott67793
                    Thanks Neil / Richard.
                    Richard, was the bore perfectly true to start with or did it have a taper which the polishing removed ?
                    As Neil said the o ring will allow for some error but would like to try and see how it goes,
                    problem is i have already drilled my ports so will have to take care !
                    Thanks.
                    #294765
                    Richard S2
                      @richards2
                      The bore was not true, as the Plug Gauge I made passed through smoothly for 1.1/8" and then became tighter. I wasn't happy to leave it that way, even though it was only a few tenths of a thou, and so with patience, the lapping removed it. Haven't got a pic of the bore/Lap etc, only this one of the end of the Cylinder with the Piston at full throw-
                      No reason why you can't do the same if you wish, despite having drilled the passages. All you'll need to do is to fully clean them out after.
                      #294775
                        Sorry for not chipping in earlier but I have been working up in london today and this is first time today I have had teh computer on.
                        I made a timber lap from a bit of hardwoodthat just entered teh bore and spun that in teh chuck while sliding teh cyliner up and down, Think I used Silvo or a similar polish. It is also worth lapping anyway as any micro ridges left from turning will wear teh O rings.
                        It was Blackgates that list teh rings, 1 x 111, 1×006, 1×010, 1xRefB (3/32) and 1 x 007
                        #294811
                        Brian Abbott
                          @brianabbott67793
                          Thanks Chaps for your advice and for the o ring sizes.
                          I have spent a happy few hours tonight sorting this out.
                          I turned a plug to use as a gauge then polished the bore with some 1200 grit on a mandrel.
                          Managed to polish the taper out so the plug passed through perfectly.
                          I did turn a brass mandrel which was a slide fit on the bore and tried lapping the bore but found this just tried to “pick up” so must be doing something wrong with that one..
                          The finish is now is very good with only some very light surface scratched so I am going to call it a day at that i think.
                          Just need to drill the fixing holes and that’s another bit done..
                          Thanks again,
                          Edited By Brian Abbott on 24/04/2017 23:05:44
                          #301516
                          Brian Abbott
                            @brianabbott67793
                            Hello All.
                            Need some more O ring help if possible.
                            I am working my way through the cyclinder making the cylinder cover and the piston gland.
                            The recess in the cover for the o ring is 0.290" x 0.250" dp and the gland measures 0.290" x 0.156 leaving a cap of 0.094"
                            Using a BS007 o ring, the thickness of this measures 0.070"
                            Should'nt this o ring be compressed slightly when fitted ?
                            Also, at 0.285" across so its loose in the bore.
                            Thanks in advance.
                            #301543
                              Yes as it is compressed into the 0.290" dia it also lengthens slightly plus you allow a bit of end float so the ring can roll slightly
                              #301615
                              Brian Abbott
                                @brianabbott67793
                                Ok, thanks Jason,
                                I will have another measure as something does not feel right.
                                Cheers
                                #304824
                                Brian Abbott
                                  @brianabbott67793
                                  Hello all. back again.
                                  Need some help, unsure of what size o ring i use in the regulator chest.
                                  I will order a set from Blackgates but none of the sizes make sense.
                                  The REF B 3/32 would be the obvious guess but this would add up to having a 0.222 OD.
                                  Is this right ?
                                  Thanks in advance.
                                  #304829
                                    Looking at a table for the fit of O rings the ref B ring has a nominal diameter of 0.064" usually these would be compressed by about 0.010" but the B ref they give 15-18 thou of compression and a wider groove to accomodate the more oval shape that will result.
                                    So if we take a mid value of 0.0165" from our nominal of 0.064" that gives the compressed size of 0.0475"
                                    Therefore 2x ring plus shaft = (2×0.0475)+0.094 = 0.188"
                                    Drawing gives 0.185" so looks like Mason went towards the max of 0.018" compression which would come out bang on 0.185"
                                    Rather than make a 0.185" D bit I would just do the counterbore for the ring with a 3/16" milling cutter
                                    #304889
                                    Brian Abbott
                                      @brianabbott67793
                                      Wonder if he made it so tight as to stop the regulator moving?
                                      Anyhow, thanks Jason.
                                      #326007
                                      Brian Abbott
                                        @brianabbott67793
                                        Hello all.
                                        Not sure if anyone's interested but for anyone building one here's a couple of pictures of the Minnie, not much progress lately but still progressing.
                                        Thanks.
                                        #326431
                                        Brian Abbott
                                          @brianabbott67793
                                          Hello All, after some help.
                                          I am just in the process of making the smoke box, am i right in saying this only pushes onto the boiler by 3/8" ?
                                          Also, what the best way to ensure this is fitted true as i am guessing an error here will create a problem when i wrap the boiler cladding.
                                          Thanks.
                                          #326587
                                            That sounds about right, looking insid ethe smokebox the rivits on mine are 1/8" in from the end of the boiler which would give 3/8" overlap.
                                            mason suggests holding a straight edge against the smokebox and chucking you have an even gap down the sides, to and bottom of the boiler, just drill through 4 holes and poke a rivit in loos to hold things, if not quite right adjust and drill a couple more holes.
                                            Cladding is not an issue as by the time you have added 1/16" of insulation the cladding can overlap the smokebox by 1/8" so the rivit setback looks the same both ends.
                                            #329309
                                            Brian Abbott
                                              @brianabbott67793
                                              Hello all.
                                              Jason, can you remember how you did the radius on the smoke box door ?
                                              #329340
                                                I seem to remember setting a tool well back on the topslide and pivoting the whole slide about its spigot.
                                                Another option would be to draw it out and workout a set of co-ordinates in say 0.010" steps to get the basic shape then blend them in by hand, not quite so easy with the flat part around the edge though using a hand graver would do it, a file catches the flat area.
                                                #329393
                                                Brian Abbott
                                                  @brianabbott67793
                                                  Thanks Jason, trying to blend something by hand will possibly be my best option.
                                                  ok..will have a think.
                                                  #336303
                                                  Brian Abbott
                                                    @brianabbott67793
                                                    Hello all.
                                                    I am about to start making the connecting rod for my 1" Minnie but not really sure where to start, has anyone got any advice or photos ?
                                                    Thanks.
                                                    #336359
                                                    Richard S2
                                                      @richards2
                                                      Sorry Brian, my model (Con Rod/Cross Head) is not as per LC Mason's design, so can only advise following his book description. page 129, fig52 and page 149, Chapter 8. I presume you have a copy?. If not, will try and interpret the essentials for you here. Certainly more straight forward than the path I chose for mine.
                                                      Edited By Richard S2 on 11/01/2018 19:53:53
                                                    Home Forums Traction engines Topics
