Brian’s 1″ Minnie Traction Engine
Home Forums Traction engines Brian’s 1″ Minnie Traction Engine
Viewing 25 posts - 76 through 100 (of 334 total)
  • #190885
    Brian Abbott
      @brianabbott67793
      Hello all.
      Still building the boiler…have decided to use PB102 for the threaded bushes, is this the best material or should i favour brass ?
      Thanks
        Definately bronze for the bolier bushes.
        Missed you request for video, will have a look.
        J
        #192769
        Brian Abbott
          @brianabbott67793
          Thanks Jason, sorry for not responding.
          Not sure how the water gauge works, understand the principle of the water levels but do you need to purge it by opening the valve ?
          Really basic stuff i guess but hoped there may be a video of someone using one.
          Thanks again.
          #192799
          maurice bennie
            @mauricebennie99556
            Hi Brian , If I have used acid on anything I give it a good soak in soda carbonate or bicarbonate, hot is best ,leave to soak ,rinse well in hot water and dry quickly by warming .Then oil or paint. Hope this helps Maurice.
            #192805
              Brian, yes you can get a build up of scum inside the glass and this can be cleared by opening the bottom valve on the glass.
              About 2 mins into this one
              J
              Edited By JasonB on 08/06/2015 17:54:07
              #193764
              Brian Abbott
                @brianabbott67793
                Thanks both, Jason that is a help, Thank you.
                Feel a little stupid asking this as I feel I should know but here goes.
                Why do I need to use Pb 102 for bushes and such on the boiler, why can i not just use copper ?
                is it because the Pb is a stronger material and holds the threads better ?
                I do no that Pb102 has a very high copper content so makes it ideal to solder to the copper but that's it.
                thanks for any advice.
                #193768
                  Good question, I too assume it is a bit harder so less likely to strip the threads as well as being easier to form them in the first place.
                  #193779
                  Brian Abbott
                    @brianabbott67793
                    Thanks Jason,
                    reason I ask is I'm about to make the pump pad on the side of the boiler
                    should I use copper or pb102, am I just over complicating things by mixing it up
                    #193781
                      Copper will be fine if you have it, I think thats what Mason used anyway.
                      #206720
                      Michael Checkley
                        @michaelcheckley34085
                        Has anyone either found or put together a materials list for making a 1" Minnie from stock (excluding the boiler materials)? This is my next model engineering project and I would like to get all the materials from Midlands show…
                        Thanks in advance,
                        #206728
                          I've not seen one for an engine from castings or all stock materials. Making a list is a good way to aquaint yourself with the drawings.
                          The set of metric drawings that are on the web have a parts list which would be a start as you could just write the sizes next too each item.
                          Edited By JasonB on 05/10/2015 16:26:54
                          #212834
                          Brian Abbott
                            @brianabbott67793
                            Hello All.
                            Can anyone help me with this one,
                            I need to drill the holes into the horn plates for the fire box stays,
                            are these taken from the template, so 1" up by 1" 1/8 across ?
                            Thanks
                            #212838
                              No see bottom of page 35 in the book
                              #213012
                              Brian Abbott
                                @brianabbott67793
                                Had to read it a couple of time but understand it now..
                                Thanks Jason.
                                #213042
                                Raymond Griffin
                                  @raymondgriffin40985
                                  Hello Brian; I am hopefully nearing completion of my 1" Minnie boiler. My pump pad is in copper; as supplied in the kit of boiler parts purchased from Blackgates Engineering. I now need to add the firebox stays on the sides. I have so far found that the construction notes need very careful reading; for example the figure on page 30 showing the drilling template indicates "RH end​" in the top right corner. I will see if my interpretation is correct! I find it easier to cut fine threads in bronze than copper. I also believe that they will be stronger.
                                  I have tried and failed (it seems very complex) to attach a photo of my boiler to date. Also found it impossible to paste my comment from a Word document.
                                  Good luck with your boiler.
                                  Ray
                                  #213123
                                  Brian Abbott
                                    @brianabbott67793
                                    Hello Raymond, not sure to the reason for the problems you are having, but please percavere as it would be good to see another build.
                                    #213143
                                    Raymond Griffin
                                      Hi Brian,
                                      It is possible that my latest attempt at posting a photo or importing text from Word, was thwarted by my using the latest upgrade to Microsoft 10 and the Edge browser. I have now transferred to my laptop which uses Linux Ubuntu. So, will see what happens when I try to attach three photos and import text from LibreOffice.
                                      I would like to contribute, but only if the technology is helpful.
                                      Best wishes
                                      Ray
                                      Looks as though it worked for the text; but unable to add the photos. Seems as though I have to put the photos in an album?
                                      #213144
                                      Raymond Griffin
                                        Well that worked. Long winded though.
                                        #213165
                                          hello Raymond, the reasons for the behaviour are two-fold-
                                          1 It lets us limit the size of all pictures (I greatly upset the mods on another forum by embedding an 80mB image…)
                                          2 HTLML in posts is disabled except in an embed media box, to help prevent abuses.
                                          Glad you got there in the end.
                                          Raymond Griffin
                                            Hello Brian, I have sent a message to your inbox. Regards Ray Griffin
                                            #215664
                                            Brian Abbott
                                              @brianabbott67793
                                              Morning all.
                                              Just for future use, what size should the boiler gauge be ?
                                              .. 3/4" 0 – 80 PSI ?
                                              Thanks in advance,
                                              #215687
                                                Mine is 3/4"dia x 100psi but 80 should do.
                                                #215688
                                                KWIL
                                                  @kwil
                                                  PB102 is a stronger material and yes holds threads better, does not tear like copper can do. Much more durable.
                                                  #215775
                                                  Brian Abbott
                                                    @brianabbott67793
                                                    Thanks Both,
                                                    #218947
                                                    Brian Abbott
                                                      @brianabbott67793
                                                      Hello all, happy new year to everyone, made an attempt and trying to solder by Minnie boiler this week, needless to say this has ended in disaster..tried several practice attempts using 424 with no real problems, after a few goes anyway, then tried to solder the firebox. Problem I seemed to be having was could not get enough heat into the job, I am using a standard sievert 28mm burner, can anyone advise what size maybe to try, 32 or 35 ?
                                                      Thanks
                                                    Home Forums Traction engines Topics
