Brian’s 1″ Minnie Traction Engine
Home Forums Traction engines Brian’s 1″ Minnie Traction Engine
Viewing 25 posts - 276 through 300 (of 334 total)
  • #480718
    Brian Abbott
      @brianabbott67793
      Thanks Dan.
      You've just hit the nail on the head, don’t know why i didn’t see it myself.
      As explained in the book, leave a little room for the slide block to move.
      Just need need to check the valve travel.
      Update!
      Much better but still happening, problem is i don’t think i have enough through to open the valve correctly.
      Never kind, keep looking
      Edited By Brian Abbott on 18/06/2020 14:20:41
      Paul Kemp
        @paulkemp46892
        Brian,
        Are you sure your eccentric rods are exactly the same length? Easy way to check is stand the strap half and rod on a surface plate with the rods vertical and try passing a pin (drill shank even of the right size) through both clevis's. If they are different lengths it can play havoc with valve events in general. I don't have any experience of Minnie and looking at the video it's hard to judge but the crank centre line seems markedly higher than the valve spindle centre line? Might be worth rechecking everything is to drawing such as distance from crank to centre of weigh shaft, throw of the weighshaft arm etc. It's not unusual with Stephenson's gear to have some kick through the reach rod to the reverser but yours does sound a little excessive. Jason B is probably best qualified to comment having built one.
        Paul.
        #480816
        Brian Abbott
          @brianabbott67793
          Thanks Paul.
          I have re-read the book tonight, and he does clearly say that this arrangement suffers from "link slip" and to leave a little free space in the link slot beyond the die block ( his words ).
          As suggested by Dan I have tried clamping the reach rod with a couple of mm clearance in the link slot and it does seem ok (ish) so I think I need to finish all the reverse lever assembly and set everything up properly.
          I am fairly sure everything is made correctly, I know when I made the eccentric rods I did take care, but costs nothing to check these things.
          Thanks for the advice.
          #480818
          Paul Kemp
            @paulkemp46892
            Brian,
            No worries, these snags can sometimes be a b*****r to find. In general TE valve gear is usually a fairly inefficient compromise, the road engine boys never really seemed to catch up with their rail brethren when it came to valve gear! Wallis and Fowler probably came closest.
            Paul.
            #480824
              Your finger on the far side holding the arm is moving which is allowing the lifting links to move up and down, once reverser is in it's notch that can't happen, Try clamping it solid while you turn the engine over.
              Also not quite low enough to get full forward and too high in reverse.
              Edited By JasonB on 19/06/2020 07:01:11
              Edited By JasonB on 19/06/2020 07:04:19
              #480915
              Brian Abbott
                @brianabbott67793
                Thanks all for your help and advice.
                #491844
                Roger Best
                  @rogerbest89007
                  smiley Great thread – you have covered a great many issues over the years.
                  Fabulous work Brian!
                  #491848
                  Brian Abbott
                    @brianabbott67793
                    Thank you, i didn’t think anyone followed this build,
                    Progress is slow admittedly, work and family take priority, but it’s getting there.
                    #491852
                    Jeff Dayman
                      @jeffdayman43397
                      It's looking great Brian! I see you are starting the beading around the tender, looks like. Tricky, but looks great when done.
                      #492069
                      peter hobbs 2
                        @peterhobbs2
                        looking good brian i have finally steamed my minnie successfully using charcoal and it steams well .the only thing now is the pump will not work against the boiler pressure,when the engine is cold it works fine.
                        anyone else had this problem
                        pete
                        #492076
                          The pump does not worrk as well when it get shot, some builders mount the pump down on the horn plate or at least space it off of the boiler.
                          #492094
                          peter hobbs 2
                            @peterhobbs2
                            thanks jason for the info i think i will try moving it to the horn plate and also fit a back up hand pump
                            pete
                            #569488
                            Brian Abbott
                              @brianabbott67793
                              Hello all
                              Just working on the Minnie water pump,
                              Anyone know what size hole should be through the check valve seating.
                              7/64 or 1/8 ?
                              Thanks
                              #569493
                              Harry Wilkes
                                @harrywilkes58467
                                Looking very nice Brian
                                H
                                #569656
                                Brian Abbott
                                  @brianabbott67793
                                  Thanks Harry.
                                  #569960
                                  Richard S2
                                    @richards2
                                    Hi Brian, Sorry for the delay. 7/64" bore for the valve seatings for 5/32" valve balls. Are you changing the pump layout/location ?.
                                    #569966
                                      Nice to be reminded of this build!
                                      Brian Abbott
                                        @brianabbott67793
                                        Good afternoon all.
                                        Could I ask any Minnie builders what thickness gasket they used between the cylinder and the boiler?
                                        The reason I ask is when I machined the base of the cylinder I took great care to make sure it matched the boiler, unfortunately, I forgot all about the gasket.
                                        Really, to make things right I should re-machine the base of the cylinder to allow for a gasket,
                                        Thanks,
                                        #593797
                                        Paul Lousick
                                          @paullousick59116
                                          If there is no allowance for the thickness of a gasket and the surfaces are flat and mate well with each other, a coating of graphite based sealant will work. (used on the end cover on the steam cylinder of my 6" engine).
                                          #618470
                                          Brian Abbott
                                            @brianabbott67793
                                            Hello all
                                            Progress has been very slow of late but thought i’d post a quick update picture
                                            Regulator’s done and the water pump is taking shape.
                                            Still lots to do but the end is in sight 😀
                                            #618483
                                            Jeff Dayman
                                              @jeffdayman43397
                                              The engine's looking really good Brian! keep going with the last bits. Did you use sealant under the cylinder or did you machine a bit out for a gasket?
                                              #618550
                                              derek blake
                                                @derekblake72550
                                                Looks great Brian, well done 👍
                                                #618682
                                                Brian Abbott
                                                  @brianabbott67793
                                                  Thanks Derek,
                                                  Hello Jeff, never got that far,
                                                  Plan now is to write a list of all the half finish bits I need to do then strip the engine and sort all the gaskets so I can get it running,
                                                  Im not planning on painting it so just need to clean everything.
                                                  Be good to get it finish, I’ve really dragged my feet with this and I’m lucky I have never lost interest.
                                                  #640430
                                                  Brian Abbott
                                                    @brianabbott67793
                                                    Hello everyone
                                                    I am working on the ash pan, damper and hinge arrangements.
                                                    I have made the hinge that attaches to the front of the boiler but am having trouble picturing the 2 small hinges that solder to the damper.
                                                    Would anyone have a clear picture?
                                                    Thank you
                                                    #640448
                                                      Last two in this album of mine
                                                    Home Forums Traction engines Topics
