Brian’s 1″ Minnie Traction Engine
Home Forums Traction engines Brian’s 1″ Minnie Traction Engine
Viewing 25 posts - 226 through 250 (of 333 total)
  • #438498
    derek blake
      @derekblake72550
      Coming along nicely Brian, good work
      Brian Abbott
        @brianabbott67793
        Thank you Derek.
        Just waiting for some more 10ba bolts to arrive, i can then bolt everything tight and check for true.
        Riveting and soldering then.
        #438887
        derek blake
          @derekblake72550
          Out of interest what part gets soldered? I bet that’s hard to keep neat.
          #438888
          derek blake
            @derekblake72550
            Wheels look lovely and neat.
            #439136
            Brian Abbott
              @brianabbott67793
              Hello Derek.
              There are inner and outer covers which get soldered onto the hubs, fixes everything together.
              When I soldered the rear hubs I used a soft solder paste, worked ok but i had an issue with corrosion from the flux.
              It has been suggested that I try an epoxy glue instead of solder but I’m not sure.
              Slight change of plan at the moment as I forgot to cut the slots that imitate the tyre tread so that’s next on the list, then solder them up.
              #439182
              derek blake
                @derekblake72550
                Hi Brian
                yes I would probably you epoxy myself, as flux can seep out over time but I’m no expert.
                i look forward to the updates, keep them coming,
                Derek
                #441172
                George Jervis
                  @georgejervis86082
                  Hi everyone
                  Just wondering when you build the rear wheels is it best to rivet the strakes on first or do the spoke and hubs first?
                  George
                  #441177
                    Strakes first while it is easy to get to the rivits
                    #441190
                    Brian Abbott
                      @brianabbott67793
                      I did mine before, as Jason said it's just easier.
                      #441205
                      Raymond Griffin
                        @raymondgriffin40985
                        Hi Brian, I don’t have the expertise to compare the relative merits of solder versus JB Weld. It seemed to me that the joints are not heated or highly stressed and are riveted. For me, joining metals with epoxy has always been successful provided that the resin is well mixed, the surfaces to be joined are roughened and that the components are kept warm to facilitate polymerization. I have seen other reports or flux residue causing corrosion.
                        Your wheels look nicely made. Ray
                        #441279
                        Brian Abbott
                          @brianabbott67793
                          Well i've done it now.
                          Decided to stay true to Mr Masons book and soldered the first one.
                          Time will tell.
                          #442103
                          George Jervis
                            @georgejervis86082
                            Hi everyone,
                            I am about to start making the front wheel hubs and cannot for the life of me find the information and measurement for them? I have the book by L C Mason and the original plans for the 1in minnie but find they a vague. Looking through the box of casting I have I have identified almost every item I need but not sure if these are the casting for the hubs?
                            George
                            My picture is he my album and I'm not sure how to put it on here thank you
                            #442105
                              can't see the pic in your album but thought they were just cut from brass bar. Page 106 has the drawings
                              EDIt, Seen the photo now you have uploaded it and yest they will turn into the front wheel hubs, all three bits in one casting for each wheel.
                              Edited By JasonB on 17/12/2019 20:39:00
                              #442152
                              George Jervis
                                @georgejervis86082
                                Hi Jason B,
                                That makes sense now, I'd asked a couple of friends what they would be for and they were not sure either, But now I can see how they will be made
                                Thank you for your help
                                George
                                #442153
                                derek blake
                                  @derekblake72550
                                  Very nice work Brian.
                                  #442163
                                  Jeff Dayman
                                    @jeffdayman43397
                                    Wheels are looking great Brian!
                                    #442313
                                    Brian Abbott
                                      @brianabbott67793
                                      Thanks both.
                                      Small victory tonight, finally sat on its wheels.
                                      Edited By Brian Abbott on 18/12/2019 23:22:41
                                      #442361
                                      derek blake
                                        @derekblake72550
                                        Hi Brian
                                        Great work, looking great 👍
                                        #449960
                                        Brian Abbott
                                          @brianabbott67793
                                          Hello all.
                                          Just in the process of turning the Chimney from a solid lump of aluminum.
                                          Can anyone tell me.
                                          Is the bore a continuous taper or dies it run parallel for the first 17/32 at the top end ?
                                          Thanks
                                          #450018
                                            I ran mine as a constant tapering bore.
                                            #450488
                                            Brian Abbott
                                              @brianabbott67793
                                              Thanks Jason.
                                              #450800
                                              Brian Abbott
                                                @brianabbott67793
                                                Hello all.
                                                On the base of the chimney there are 4 – 8ba bolts attaching it to the chimney saddle.
                                                Spaced equally on a 1 3/16 pcd these seem really close to the edge.
                                                Is this correct ?
                                                #450801
                                                norman valentine
                                                  @normanvalentine78682
                                                  On my Minnie I bored it parallel but stepped it. At first it looked horrible as you could see the steps , a quick spray with Matt black paint hid it, I don’t intend to steam mine but soot will do the same job on a working model.
                                                  #450803
                                                    Posted by Brian Abbott on 05/02/2020 15:57:37:
                                                    Hello all.
                                                    Is this correct ?
                                                    just looked at mine which I assume I did to drawing and they are quite close, the hex heads come right to the edge of the flange but there is not much space between them and the vertical part of the chimney base so you could not move them in much maybe only 1/32" off the PCD.
                                                    #450806
                                                    Brian Abbott
                                                      @brianabbott67793
                                                      Thanks for the reply's
                                                      I think i am going to bring them inboard and use one size small heads..
                                                    Home Forums Traction engines Topics
