Bread Board Wire
Bread Board Wire
Home Forums Electronics in the Workshop Bread Board Wire
  • #32016
    Speedy Builder5
      @speedybuilder5
      Wire for connecting electronic components
      Speedy Builder5
        @speedybuilder5
        Many years ago – well, nearly 40 years ago, we used a fine solid copper wire which was insulated to make connections on 'Spot board'. There was no need to strip the insulation off when soldering as the heat of the solder melted the insulation and didn't seem to upset the solder joint to a component.
        Anyone know what it is called and can you still get it ?
        BobH
        #403856
        not done it yet
          @notdoneityet
          Were ‘bread boards’ not just plug in as temporary circuit arrangements?
          The insulation would not pass through veroboard holes, where the conductors were soldered on the back side of the board. Never came across a ‘spot’ board. What did I miss?
          #403858
          peak4
            @peak4
            Try "Solderable enamelled coper wire". for instance this one from Farnell
            Bill
            #403871
            John Haine
              @johnhaine32865
              Note that it needs a very hot iron to self-flux. If you have a variable temp iron remember to turn the temp down afterwards as excessive temperature seems to kill bits.
              #403872
              Mike Crossfield
                @mikecrossfield92481
                A search for “self bonding copper wire” will give you dozens of hits. Many self bonding enamelled wires are directly solderable.
                #403873
                Georgineer
                  @georgineer
                  I forget the name of it, but the stuff we used in the seventies gave off toluene di-isocyanates (TDIs) when heated, which could cause lung sensitisation and breathing problems. I hope the new solder-through insulations don't do things like that.
                  Mind you, the resin flux (colophony) wasn't very lung-friendly either. I look back in amazement at the perpetual fog in the wiring shop and think of the effect it must have had on the wiremen and women who were in it all day, every day.
                  George
                  #403926
                  larry phelan 1
                    @larryphelan1
                    Might explain why some of us have breathing problems now !! Workshop conditions in those far off "happy" days were far from ideal. H&S ? Who are they ?
                    #403936
                    Mike Poole
                      @mikepoole82104
                      Kynar was a wire I have used that could be soldered without stripping.
                      #403937
                      Boiler Bri
                        @boilerbri
                        I think these days wire strippers are very advanced and do the job so well. No need to poison yourself just get a good set of strippers.
                        Bri
                        #403940
                        JC54
                          @jc54
                          Posted by Boiler Bri on 06/04/2019 20:21:50:
                          Bri
                          I think the wife might complain..
                          #403944
                          Speedy Builder5
                            @speedybuilder5
                            Thanks guys, found small reels on A bay at an acceptable price.
                            BobH
                            #403952
                            Bazyle
                              @bazyle
                              I knew it a Verowire. I wonder how long the insulation lasts as I still have some.
                              #403976
                              Rik Shaw
                                @rikshaw
                                I have not used my breadboard in thirty years since I made my first metal detector. I used to strip the thin multi coloured wires from telephone cable and solder a Veropin on each end – very handy those colours when identifying what goes where!
                                Rik
