Mark – unfortunately, it's the underside of the deck, so it gets sand-blasted (dusty conditions in summer), and caked with pulped wet grass. Paint doesn't stand a chance…
Brazing preferred because of fillet welds, with different thickness sheet/plate, so – at least at my skill level – undercutting, when welding, is an ever-present risk. Also, the speed of brazing was welcome in the difficult and uncomfortable positions my old body was required to adopt. Torch access always seemed obstructed by another bit of the deck. Using the pedal when standing, kneeling or crouching is always difficult… But using fixed current to braze was OK, whereas it would have caused holes, if welding, as I had to stop and start a lot.
With hindsight, I should probably have used chains of short weld runs, say 1" long, like the original MIG welds.
I'm a bit surprised that TIG brazing isn't more popular – it's a lovely technique, and poses little risk to the base metal, since the arc is always confined to the braze bead.
