I called a company today (in Glasgow) that has indexable holders and tips that seemed very competitively priced. I explained I wanted to cut RH and LH inside and outside threads. The person I spoke to was very knowledgeable and did not try to sell me anything, in fact he recommended I by brazed tip tooling!
I found out that the holders to cut LH and RH are different and need different tips. We discussed ‘laydown’ tooling and how ‘shims’ are needed to tilt the carbide insert. All in all it seemed to get quite involved. I doubt I will need to cut threads like these very often so dint want to invest a fortune in tools that wont get much use.
Clive,
I do understand your explanation. I want the male thread to be right (and look right) and conform to the ISO standard for M48x3, not having a test gauge or anything of that thread the ready profiled tips do appeal.
David,
I can see me getting the Chronos kits (but not necessarily for this job) which look incredible value. I presume they are only for RH threads though but it does not state it on their website.
Chris,
I have only ever used the cross slide for feed and had no problem so will do the same again.
Ian
