Thats going to be a bit of a sod, because its thin so, unlike parting off bar with tailstock support it may well collapse on you. I think you might be unwise going that route.
I would put it the into a fixed steady and part off outboard of the steady. The length won’t go into a Myford as is, so you could just butcher the excess excess off? But that way you know its not going to do a swerve under cutting loads which are some way away from centre and therefore exert some leverage.
Fixed steadies.
Well it don’t take the brains of an archbishop to work out that the Myford one won’t take it!
MES make a big dia kit. If thats too much, for a one off, a bored hole in a bit of 3/4 ply clamped vertically will do it. Make the bed fixing, attach the ply plate. Mark centre form the headstock. Then mark hole reasonably accurately. If you have a boring head you could finish with that, but thou accuracy is not essential particularly as the case is tapered.
If you need an adjuster, a slit and a carpenters screw will do the biz.
IRRC that’s the method Ivan Law recommends for doing the bearing seats in the quill of the Dore Westbury so its capable of good accuracy if need be. I didn’t use it personally because I had built the big steady sometime earlier.
If memory serves me right that case was also used in the 105MM Tank Gun. Different projectiles of course. And hence on both sides of various wars bacause we sold a lot of them!
Edited By meyrick griffith-jones on 12/01/2010 12:49:44
Edited By meyrick griffith-jones on 12/01/2010 12:51:48
