Hello chaps and season’s greetings to one and all,
Regarding your comments about skimming brake discs and subsequent inspection.
For inspection, all brake discs are given a width/thickness tolerance in the MOT (annual test) manual for every model of car.
Although it is obviously to ensure sufficient strength for safety, the main reason is for the travel of the caliper pistons.
The caliper piston has only so much travel; if the pad wears to just off the backplate and the disc is already worn, there is a danger of the piston seal leaving its seat and draining the brake fluid.
HGV disc brakes, being much thicker, and subject to much higher braking forces which, in turn, lead to much higher heat generation, do craze, but nowadays this tends to be only on the surface.
Back in the early days of HGV discs (late 80’s/early 90’s) Iveco discs on the Eurotech and Eurostar have been known to shatter…I know, it nearly happened to mine!
Andy
