Rather than muck up what is not a very large mill bed, I think that I’d be more inclined to make an adaptor plate for the rotary table that enabled you to mount it using the two slots you already have. I made one for a 6″ Vertex a while back, but that was for a slightly different reason having everything to do with the handle… but if you use a bit of gauge plate, it’s not too difficult to extend the footprint out to the slots you already have. I used counterbored bolts with slightly reduced-height heads to mount the rotary table to the plate (so that it remains flat on the bed), and everything else is self-explanatory, I think.
(David posted whilst I was writing this, but essentially we’ve suggested the same thing)
Edited By Steve Garnett on 18/08/2010 15:28:36
