Having
one of these machines that I would like to run from a PC, I was wondering if
anyone had carried out this conversion, if so how would you rate the skill
level required?
Basically there is information on the web on how to do it, but be prepared to change the stepper drivers, remove the processor pcb….and loose the front panel switches unless you invest in something like the PoBoard.
You may also have issues with the DC driver for the motor…. dependant on what is there you might have to provide an isolated DC supply for the 0-10v input.
not sure if you’re still in need of help with this, it’s a relatively easy conversion if you use Mach3 as the controller. You can use the existing steppers, drivers, psu and spindle drive, and you could do the conversion relatively cheaply.
If you need any help, pm me.
Author
Please log in to reply to this topic. Registering is free and easy using the links on the menu at the top of this page.
