Woohoo!
It's up & running (with reservation as I've detailed at end of post)
Photos added of the process of getting the motor & countershaft assembly installed.
I decided to use the BMF motor instead of the TEC one, as the bigger one has mounting feet with enough adjustment to get the correct belt tension. Using the TEC would have been a PITA getting it mounted so have put it aside for future use.
After much thought that included studying the the motor compartment as well as various ways of lifting the motor/countershaft assembly, I decided to make a sling to lift it up.
The shaper has very convenient lifting holes front & back, and passing the rope through the rear ones, suitable secured on the left hand side, brought it in front of the motor so that it took the weight on the motor platform, through the right hand hole, I was then able to heave the whole unit up high enough to get the pivot bolts into their respective slots, having secured the rope round the belt tension lever.
(Edit: Must remember to tighten the pivot bolt lock nuts!)
Couldn't quite believe how easy it turned out, after the obvious off day I was having taking it all out, but it does of course help understanding how it actually goes together in the first place.
I did think of using a scissor jack to help lift, but that was more hassle than worth.
Everything else connected up without a problem and time came to get it powered up, after oiling all parts required.
Then the hunt was on for the longer V-belt I had just purchased. Could I find it, could I heck. Lounge, office, carport & garage twice revealed nothing. Then I remembered a length of Twist&Lock belt that came with the lathe, and it was the perfect length, so on it went. Hooray.
Switched on, twiddled the pot and nothing! Nada. Not so much as a hint of moving!
After certain Anglo-Saxon words has been said, it was time to investigate.
Up till then, I had only moved the ram using arm power by way of a vice handle on the pulley drive.
I decided to loosen the gib adjustment screws and the machine was off and running.
I did a suitable jig whilst watching the ram move smoothly & freely after who knows how many years of inactivity.
Oil was then squirted at regular intervals along the dovetail on each side of the ram, with black gunge eventually being squeezed out to run down the front and rear.
I suppose I should have removed the ram to clean all the parts first, but didn't, as moving the ram by hand it felt quite free. I must have used more force than realized.
Eventually the dovetail oil became clear, and I let it run for about 15min to ease things.
This all took place on Saturday.
Another look for the errant V-belt on Sunday morning found it snuggled up against the compressor where I had no doubt pushed I out the way. I had, by then, ordered another! Oh we'll.
Today I decided to adjust the gib, & that's when things started to go wrong!
The bolt holding the Crank gear sliding block kept coming loose,
I had made the gib a tad too tight, so slackened the grub screws off once again.
This bolt is threaded all the way up to the head, with the threads that pass through the sleeve, on which the sliding block moves, having been crushed, which may have just happened, I don't know.
It looks original though, having a square head.
It really has to be pulled up tight, but has still worked loose a couple of times. There is a spring washer under the square head shoulder.
Any suggestions appreciated.
Geoff – Champing at the bit to start shaping. Still can't believe it's ready to do some work
