Posted by Saxalby on 04/08/2022 21:07:37:
Mines a bit smoother round the edges – but still a bit rough looking.
Maybe a welding apprentice did a job lot on Friday afternoon
Reds Barry
Mine isn't much better, but I think a previous owner has tidied it up a bit.
The ratchet was also retained by a simple grub screw, but I've just made a knurled thumb screw, after adding the vertical feed.
An interesting observation though is that whilst the horizontal feed worked fine before, after adding the vertical feed cluster, it was catching on the inside of the guard.
It seems that the outer of the guard was a bit high and forward, so I slotted the screw holes and moved it a bit.
This freed everything off nicely, but so much that the horizontal feed axle now turns easily enough that it no longer ratchets, just oscillating back and forth due to the wear in the bronze nut behind the table.
I've effected a temporary repair by adding an O ring behind the micrometer dial and compressing it up against the guard; this allows just enough friction for the horizontal feed to ratchet, rather than just wobbling about in the backlash.
I now need to work out how to extract the feed nut from behind the table.
Bill
Edited By peak4 on 04/08/2022 22:17:31
