Posted by Clive Brown 1 on 27/03/2022 19:38:55:
I agree that a 127 gear is large, although the standard Boxfords do accomodate one easily enough. I was trying to highlight that although 64 is close to 127/2, 54 isn't so very close to 100/2, so the Boxford conversion gears for the VSL lathe is not simply a case of halving the size of both gears to give a "near-enough" ratio,.
lathes.co.uk have an interesting comment in their VSL information:
'… on these lathes a screwcutting gearbox was standard – but some had different internal ratios and the English/metric and metric/English conversions gears arranged to be more compact with pairs of 64/54t and 76/65t respectively instead of the usual 127/110t (inch to metric) and 135/127t (metric to inch) gears. At one time it was believed that all gearboxes on the L00 VSL lathes had the altered internal ratios but several examples have been found in the USA (one being a VSL500 manufactured in 1977 with serial number V.S.L. 71861-L00) where this is not the case, the gearboxes being of the earlier, ordinary type. It is suspected that, while Boxford fitted a different gearbox to the earlier VSL models with the L00 spindle nose, this practice was discontinued and later editions of the manual not updated to reflect the change. If you buy a gearbox-equipped lathe that appears not to generate the pitches shown on the screwcutting plate check the special manual produced by lathes.co.uk, it shows all the ex-factory arrangement of the changewheels.'
As there are VSL variants, it's necessary to identify exactly what gear-ratios are fitted to David's particular machine before rushing to buy a metric conversion gear pair. The special manual sold by lathes.co.uk might reveal all instantly. Otherwise, possible to work out what's needed from the lead-screw pitch and available gear-box ratios.
Another good news / bad news answer. Good news, David's lathe will do metric in the usual way by fitting the appropriate change gears. Bad news, finding what the appropriate change gears are isn't easy because VSLs aren't identical. Homework required.
David doesn't mention having any change-gears : if the lathe came with a box of accessories, the metric gears might be in it?
