So – time to give the full backstory
I have a wee workshop beside my garage which I use for woodwork – having a combined workshop in the garage wasn't good – wood don't like engine oil and engines don't like sawdust!
I have a 3 phase converter which i originally had running my wadkin bursgreen bandsaw and my Union Graduate lathe. Both ran great but I got a bit fed up changing the connection and settings on the converter every time I wanted to work the 'other' machine. One day a friend offered to add some weird gizmo -that I now know to be a VFD – to my woodlathe to allow it to be fed straight from the 240v supply. Ideal said I, after he told me about the variable speed etc.
However….. when roughing or turning larger dia wood blanks – specially out of balance blanks the woodlathe has to be run at fairly low RPM and it just doesn't have anywhere near the torque it had before the conversion and it kind of spoiled my experience to the point that I avoided woodturning for a good couple of years.
Spring forward to current times and I am looking to get a system that will work my Boxford in the way it's meant to be used…….
I was right on the point of ordering a 3 phase + VFD when Speedy made his point about the reliability of VFD's and the cost of replacement.
I'm happy to spend a wee bit more – looked at the website recommended earlier and its around £200 – £220 for the complete 3 phase system with VFD – if it will give me the best solution.
There does seem to be an argument for single phase from a cost point of view although as previously mentioned – I'm a bit clueless in this area and don't really know what else I need, do I just buy a motor (££?) and pop that in and it works or do I need other gubbins and have to rework switches etc?
I'm still leaning towards the 3 phase but want to make sure if I do go that route that I get a reliable VFD . I'm also really enjoying all these different points of view and appreciate all the advice folks are giving. I'm happy to take the time and listen to folks to make sure I opt for the best all round solution
thanks again
ewan
