I recently bought a run down Boxford lathe knowing it needed some TLC 9 (I like a challenge) . I have it up and running bar the cross slide feed screw ,which was bent on the outer end (handwheel side of things ),I've managed to source the little casting on the front of the cross slide which was broken . the hand/thumb wheel was absent too . I've tried to straighten the screw which was not very successful ,so I tried to do a dowel and pin repair which turned out ok but I'm just not 100% happy with .
These parts are hard to come by and I appreciate that, I just wondered would anyone on here have any pointers where I may source the two parts ? the hand/thumb wheel ,micrometer dial
This is the leadscrew
Sean
Edited By sean logie on 07/11/2021 14:35:37
