Hi all,
Forgive a newbie his first question…….
I have searched high and low on t’internet and cannot find a definitive answer to my question. I hope someone here can help because SURELY it’s a problem solved by many over the years……………
I have just purchased a Boxford Model A lathe. It has the Imperial screw cutting quick change box and 8TPI lead screw. It has the standard imperial setup of change gears between the tumbler reverse (AKA spindle) and the gearbox input shaft i.e 20T, 80T idler, 56T (with 40T on same shaft but not engaged).
With my lathe came the gears which many sites (incuding lathes.co.uk) specifiy are required to enable this machine to cut metric threads.
i.e. 24, 26, 28, 32, 36, 44, 48 and the all important 127/100 compound gear.
What no web site that I can find does explain is HOW are these gears used?
I have found mention of how to set up a LOGAN lathe (which apparently has the same box?) and that specifies MM Pitch = (40/Box Setting) * (spindle gear/gearbox gear). From this I deduce that if I put a 24T on the spindle driving the 127T compound and then drive a 48T on the gearbox from the 100T of the compound I should set the gearbox to its 20TPI setting and this should give a 1mm pitch.
Unfortunarely it DOESN’T!!!!!
Has anyone got the definitive low down on how this should alll work for a Boxford Model A? Instructions need to be clear for a dummy like me!!!!
Thanks in advance.
//artyn Bannister
