boxford lathe upgrade?
Home Forums Beginners questions boxford lathe upgrade?
  • #559239
    banjo bob
      @banjobob30482
      Hi
      awaiting delivery of a boxford cud , can this be "upgraded" to aud level using parts from a damaged aud? thanks
      banjo bob
        @banjobob30482
        #559319
        Hollowpoint
          @hollowpoint
          Yes and no. I believe most of the parts are interchangeable but IIRC some AUD models are 5" inch centre height while the BUD, CUD etc is 4.5" inch.
          #559323
          Gavlar
            @gavlar
            All the parts are interchangable. MK1 and MK11 Boxfords are 4.5" and the MK111 is 5". It doesn't matter if it is an A, B, or C model. The gearbox is pretty much the same from the earliest rear drive models up to the last of the underdrive models and will be interchangable, regardless of centre height or age.
            The 5" models have a slightly taller headstock, thicker base to the tail stock and a slightly meatier compound to make up the extra height. Other than that, no real differences.
            The B and C models even have holes drilled in the bed to mount the gearbox without modification.
            To upgrade a C to an A you would need the gearbox, leadscrew (you may be able to modify the original leadscrew) and apron. I think the saddle is the same but I'm not sure as the C didn't have power cross feed. It might just need an the cross slide leadscrew swapped over.
            Edited By Gavlar on 21/08/2021 23:38:06
            #559433
            Bazyle
              @bazyle
              There are various different bed lengths so the leadscrew RHS end support might not line up but any competent engineer can sort that out.
              #559438
              Clive Brown 1
                @clivebrown1
                I upgraded my 5" ME10 from "B" to "A" spec. by fitting a gearbox from an older 4.5" lathe. No problems, the main job was shortening the leadscrew to connect to the gearbox output shaft. As it will pass through the spindle, machining was straightforward.
                I assume that the "C" lathes have the necessary drive keyway in the leadscrew even though the longitudinal feed uses the half nuts.
                #559537
                RichardS
                  @richards31161
                  The leadscrew on a C does not have the drive keyway.
                  You will need to swap out at least the apron as well if you want power feeds.
